Tire noise or something wrong?
    Results 1 to 8 of 8
      Mar 2017
      Southern California, USA
      I hear a "hum" coming from under the car when turning left or right greater than 60 degrees. There might even be a light thump thump as the wheels turn. I feel nothing in steering wheel. I never hear anything driving straight. I also tested when stopped by turning wheels full left then full right, no unusual noises.*
      Does this sound like something is wrong with my new 2020 XC90 T8 or do you think it's just typical of Pirelli Scorpion Verde All Season tires?
      Jul 2016
      Quote Originally Posted by sdedson View Post
      Only way to find out is to go to the dealer and drive another xc90 with the same tires
      Sent from my SM-N975U using Tapatalk
      Feb 2019
      Long Island NY
      How loud is the hum and how many miles on those tires? I had a slight hum but going straight or turning ,went away. Yours should be checked as turning hum remind me of wheel bearing, but on a brand new car? Unlikely
      SwedeSpeed.com
      Mar 2017
      Quote Originally Posted by rkohou View Post
      Less than 500 miles...
    7. #5
      Feb 2018
      USA
      No to both. How's the cold tire pressure in all four tires? Hopefully an easy thing to check and eliminate.
      2019 XC90 T8i (OSD 2018 July)
      “Scientists study the world as it is; engineers create the world that has never been.” - Theodore von Karman
    8. #6
      Mar 2017
      Quote Originally Posted by likeXC90 View Post
      Thank you @likeXC90, you were correct! Apparently dealer filled 12 PSI below recommended tire pressure and set it (I think they do this to soften the ride during test drives). I pumped them up to recommended and the noise went away.
    9. #7
      Feb 2018
      USA
      Excellent!
      Enjoy your ride fellow T8ster
    10. #8
      Mar 2017
      Excellent!
      No joy ;-(
      https://r.tapatalk.com/shareLink/top...ink_source=app
      2020 T8 ERAD issue
    11. Remove Advertisements
    Similar Threads
    1. Replies: 61
      Last Post: 04-18-2011, 10:42 PM
    2. ODOMETER GEAR SAGA, Or, If It Can Go Wrong, It Will Go Wrong For Me.
      By JBLasVegas in forum 240, 242, 244 & 245 (1974-1993)
      Last Post: 12-17-2008, 03:50 PM
    3. Something Old - Something New - And Something Laser Blue
      By Kaizai in forum S70, V70 & V70XC (1998-2000)
      Last Post: 06-22-2006, 11:02 AM
    4. Replies: 0
      Last Post: 02-13-2004, 02:25 PM
