Oil leak
    Results 1 to 7 of 7
    Thread: Oil leak
      Aug 2017
      Oil leak
      I just purchased an 02 v70 xc that needed the timing belt redone as it had an oil leak from the front cranck seal so i replaced the seal did the whole timing belt kit you know water pump tensioner pulley put it all back together added oil started car oil came flooding out so i took everything apart again replaced all the seals for the oil pump put it all back together again added oil turned the car on no leak so i put the fender liner back on put the tire on took it for a short shake down cruise let it get up to temp but didnt take it on the highway got back home checked under and no leak now this morning i ran the kids to school and on the way back i got a no oil pressure stop and shut off engine i was only a few blocks from home so i just drove it home as the warning and the oil light would come on then go off again so i thought maybe its the pressure sensor got home and parked it add a little bit of oil cause maybe it needed a half a quart more for turbo lubrication or what ever and then oil came flooding out the side again i know i tightened everything down so could it be a bad oil pump? Cant quite tell where oil is coming from but looks to be near the timing cover or oil filter oil pan area that side of the motor any thoughts would be appreciated. Sorry about the long story but want to give all the info i can.
      P.s. the volvo sat for about a year before i bought it
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      How's the PCV?
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15.5 XC60 T6, '16 V60 P*
      Apr 2013
      Toronto, Canada
      Quote Originally Posted by Wayne T5 View Post
      How's the PCV?
      ditto - it's likely hemorrhaging oil from one of the cam seals. Hard to tell unless you take the side-timing cover off. You need to replace your PCV stuff before replacing any more seals otherwise seals will just be pushed back out. If you are lucky, you won't have pushed rear main seal out (rare) but do check to see if you now have a leak on LHS of engine. If you do, you have some more quality time to spend with your car.
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
      SwedeSpeed.com
      Aug 2017
      I have not checked the pcv didnt know i needed too hopefully that is whats wrong. I will look at it tomorrow and will keep you posted thank you for the quick responses.
    7. #5
      Apr 2013
      Toronto, Canada
      PCV is arguable the most common cause of these cars being scrapped/abandoned for mileage north of 150k miles. Either because seals blow and work is cost prohibitive to perform or because seals blow and engine fries due to lack of oil.
      It really should have been a mandatory service every 100k miles.
    8. #6
      Junior Member freeheelin's Avatar
      Jan 2018
      B.C. interior.
      Is this the magic number/mileage the PCV needs to be tended to?
      2006 FWD V70 2.5T Sport Edition 79,000 mi. --Roxy Roller
    9. #7
      Sep 2017
      Colorado
      Quote Originally Posted by freeheelin View Post
      Not necessarily, though a good ballpark. I think Volvo has a system inspection recommended somewhere around that mileage. A lot of folks seem to start seeing issues around that mileage. My '06 had it done due at ~65K to the top hose cracking off a couple years before I bought it, whereas my '01 is still on the original as far as I know (being an NA might help?) and passes the glove test easily. I check yearly on both cars, though I'm only putting 4-6k on each per year now.
      2001 V70 Silver - 197k miles
      2006 XC70 Ocean Race - 94K miles
      (Past: '94 944 turbo, sold at ~220k miles)
    10. Remove Advertisements
    Similar Threads
    1. Power Steering Leak + Rear Main Seal Oil Leak
      By mateo319 in forum S80 (2007-2016)
      Last Post: 04-03-2015, 06:08 PM
    2. Source of oil / power steering fluid leak leak
      By mumpsdba in forum S70, V70 & V70XC (1998-2000)
      Last Post: 03-16-2009, 10:22 PM
    3. My Oil Pan craked, small oil Leak
      By dicostal in forum S70, V70 & V70XC (1998-2000)
      Last Post: 04-05-2006, 10:33 PM
    4. '98 S70 T5 oil leak...turbo but not oil return.
      By MadeInJapan in forum S70, V70 & V70XC (1998-2000)
      Last Post: 10-24-2005, 12:11 PM
    5. Turbo oil leak/ was mystery oil leak
      By Axel in forum General FWD & AWD
      Last Post: 10-30-2003, 07:50 AM
