My V70T5M just had PCV induced oil seal failure on high mileage engine. Fix or swap?
    Results 1 to 10 of 10
      Aug 2013
      My fault for not servicing PCV, but my engine dumped all its oil out today. Managed to pull over and shut down very quickly. Engine has 230k on it and other than some piston slap when cold, has great compression and doesn't use any oil. There are no local Volvo shops around, but local jack-of-all-trades can probably fix (hopefully camshaft) seal and PCV. Don't have an estimate yet, but assuming US$1500 parts & labor.
      I just noticed a B5234T9 online with less than 50K miles for $2000. No idea how much labor is involved in swap, or if the T9 can be swapped for a T3 in my car, but was wondering if I should just replace the engine. I'm probably due a clutch soon as well, It's been forever.
      Since there are very few nice manual transmission wagons out there at any price, and mine is otherwise in pretty nice shape, I don't mind spending the money, but I'd like to make the smart choice here.
      Any Thoughts?
      2010 V50 T5M R-design Titanium Gray Metallic (the little one)
      2003 V70 T5M Titanium Gray Metallic (the big one)
      Apr 2007
      Nashville
      If you don't have a knock I'd slap some cam seals on it and replace the PCV system with the updated banjo bolt. Way easier and cheaper than swapping an engine.
      04 V70R Flash Green/Atacama6MT
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Likely cam seals.
      2k is a bit high for a T9 engine. It should be a nearly direct plug and play, likely some little fiddly bits that haven’t been figured out with p80 to p2 swap yet like what coolant lines to use.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      SwedeSpeed.com
      Junior Member rocketscience55's Avatar
      Mar 2017
      Washington D.C.
      See if there is oil on top of the transmission. When my 850 PCV failed and pushed out my cam seals I had a lot of oil on top of the transmission which helped me determine that I had not blown the rear main seal. PCV also is not super difficult to do yourself if you watch the FCP videos. I say fix.
      2019 XC40 T4 FWD, Momentum with Premium and Vision Package - Hers
      2013 C30 Polestar #141/250, Mototech exhaust, Volvo Skid Plate, RacingBeat RSB, - His
      1997 Volvo 850 N/A with 240k, 1 owner, SOLD 2017
      2000 C70 Convertible 5sp HPT, SOLD 2011
    7. #5
      Aug 2013
      All the oil was coming out from behind the timing belt cover on the side opposite the transmission.
      Quote Originally Posted by rocketscience55 View Post
    8. #6
      Aug 2013
      Are there any "while you're at it" things to do? I think I've got a long time until timing belt is due, but might as well, how about water pump, etc?
    9. #7
      Aug 2016
      Swap the seals and call it a day. These engines are tanks.
      If you are doing the timing belt might as well do water pump and tensioner.
    10. #8
      Jul 2018
      Toronto
      Could also be the crankshaft seal which is a much easier and cheaper job. That's where mine started leaking. Note I did not have the same catastrophic failure.
      01 v70 2.4T
    11. #9
      Mar 2017
      Washington D.C.
      Quote Originally Posted by Neve View Post
      If the oil is coming from behind the timing cover it could be a cam seal on that side. Either way I would recommend replacing the timing belt because I believe to replace those seals you'll need to take off the belt anyway. Also its never a bad idea to replace the tensioners and water pump at the same time, assuming they're not brand new. So for this I'd replace, Seal, PCV, Timing belt, water pump and tensioner.
    12. #10
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      All of the above. May as well inspect and replace some hoses at that mileage too.
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    13. Remove Advertisements
    Similar Threads
    1. Crankshaft Seal & Oil Pump Seal Replacement
      By trailor in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 10-14-2019, 05:13 PM
    2. Replies: 0
      Last Post: 03-08-2018, 01:40 PM
    3. I hope the city enjoys paying for pothole induced flat tires!
      By HeroofTime in forum S80 (1998-2006)
      Last Post: 04-07-2014, 07:42 PM
    4. Donut-induced AWD failure?
      By andrewmo in forum R Forum (2004-2007)
      Last Post: 12-14-2009, 03:54 PM
    5. Rain/Slush induced Driveshaft/exhaust interference - No "R" fix?
      By rogersampson in forum R Forum (2004-2007)
      Last Post: 12-06-2005, 08:32 PM
