M66 Rebuild question
    Results 1 to 6 of 6
      Junior Member sdutley's Avatar
      Mar 2019
      I've had my C30 for about a year now, and when I purchased it apparently it had the wrong size axle on the right side. It ran dry of oil for the manual transmission. I managed fix the issue and refill the transmission but only now 10 months later it seems to be making clacking noises and my mechanic thinks it may need to be replaced.
      Are there any rebuild kits out there or is the better route to purchase a used transmission and just swap it?
      I have a 2011, which I think that means it is the later M66 Transmission.
      Any information will be appreciated.
      Jan 2019
      Get a 2nd opinion since this is an major repair. Is he an Independent Volvo specialist?
      Buying a used one would be the cheaper route in regards to "better" as for affordable.
      Mar 2019
      He's independent but not a Volvo specialist. I'm in a small town so I take my car to someone I trust. I'm leaning towards just buying a used transmission if that's what I need.
      SwedeSpeed.com
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      Clacking noise might also be the dual mass flywheel going bad. Def get a second opinion from someone who knows modern Volvos.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
    7. #5
      Member lookforjoe's Avatar
      Mar 2008
      NY
      If the transaxle was run for any length of time without oil, it's toast. Mine developed a balky reverse after just being a quart low for a few hundred miles when my left axle unseated. Just get a used transaxle & be done with it. There are no rebuild kits. It is possible to replace all the bearings, but not from Volvo. Seals you can get from them.
      VandSautodismantlers in CA has much better prices than erieVoVo, but no warranty.
    8. #6
      Mar 2019
      Buying a new transaxle is what I'm leaning towards at this point. The balky reverse gear is a similar symptom to what I have as well. Did you ever experience any symptoms in the steering as well?
    9. Remove Advertisements
    Similar Threads
    1. Can M66 AWD Trans be used for M66 FWD? Thoughts
      By Oceans60R in forum R Forum (2004-2007)
      Last Post: 02-05-2020, 06:49 PM
    2. WTB - S60R M66, S60 T5 M66, or S70 T5 Manual
      By s70t5ing in forum Want Ads
      Last Post: 09-13-2017, 01:41 AM
    3. M66 snabb short throw kit/M66 pdv high strength collar gear
      By kalpauly in forum FWD & AWD Parts For Sale
      Last Post: 01-31-2017, 09:33 PM
    4. M66 transmission / m66 Angle gear
      By VOOk89 in forum Want Ads
      Last Post: 12-20-2013, 06:38 PM
    5. M66 Tech Question
      By Chilled Man in forum R Forum (2004-2007)
      Last Post: 12-19-2009, 03:54 PM
