Sunroof
    Results 1 to 6 of 6
    Thread: Sunroof
      Aug 2018
      Sunroof
      So I noticed this morning when I got home that the lining around the rear of the panoramic sunroof is slightly higher on passenger side than drivers side. Like itís not tucked in as much. Not sure if I should be concerned or am just OCD. Guess as long as itís not leaking I should just let it be?
      Sep 2019
      So Cal, USA
      Canít tell what model you have and for how long ó and a picture may help us understand the concern, but for me, if itís more esthetics that bug me on a newer car Iíve taken delivery on, I add it to a list I create and take in to discuss on my next service appt. OTOH, if itís creating wind noise, water entry, or the moonroof that wonít open, etc that may cause more damage over time, then I would consider going in earlier than later to have it looked at. Good luck with your resolution!
      Bert
      Present: Ď20 XC60 T8 Inscription
      Past: Ď15 Tesla S90D; Ď14 SLK250; '13 RX450h; Ď09 335i; Ď06 RX400h; Ď02 SC430; Ď99 RX300; Ď95 SC300; Ď91 Legend...
      Aug 2018
      18 MY Momentum. Not the best pic but best I could do at the time. Itís clearly higher than the other side.
      SwedeSpeed.com
      Aug 2016
      Not only is the picture terrible, it also doesn't give us a larger frame of reference of where in the car we are supposed to look...
    7. #5
      Member satrya's Avatar
      Jan 2018
      Fremont, north california
      Is that taken from the 1st row facing backwards/up towards the piece shown in the middle of this picture (which I took from the 2nd row facing forward/up:
      Denim Blue 2018 xc90 T6 Momentum+
    8. #6
      May 2018
      Lewisberry Penn
      It looks like a picture from the front seat back, but I can't see the uneven point asked about. I think it should be the same though and would probably get it check out.
      Volvo Sales Guy
      VCOA Member
    9. Remove Advertisements
    Similar Threads
    1. Replies: 22
      Last Post: 12-17-2019, 07:27 PM
    2. Sunroof drain thread to end all sunroof drain threads
      By 2008 V50 T5 AWD in forum S40 & V50 (2005-2012)
      Last Post: 09-19-2018, 09:30 PM
    3. Sunroof drain clog?
      By Eagles_00 in forum S40 & V50 (2005-2012)
      Last Post: 10-16-2017, 01:58 PM
    4. Replies: 8
      Last Post: 04-19-2010, 01:02 AM
