Ignition coil question
    Results 1 to 7 of 7
      Oct 2016
      I have 3 of the IPD HD coils that I bought from here. Can I install these with 2 new Bosch coils? IPD has no plans to remake them. Iím about to do my plugs so I figured Iíd do the coils while Iím in there.
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Replace them all with OE equivalent bosch. The IPD coils are notorious for failure and not worth installing.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      I had IPD coils, epoxy started to crack, sent them back for warranty, got new ones and never looked at anything else. Bosch are best.
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
      SwedeSpeed.com
      Member T501's Avatar
      Mar 2005
      Florida
      My IPD coils lasted about 80k miles before they started to fail. Not as long as OE but still reasonable. If you have them thereís really no reason I wouldnít put them to use especially considering how easy it is to replace coils when they do fail. Most of the time I was running 4 IPD HD coils and one Bosch. Probably not ideal but it never caused any noticeable problems.
      David - '01 S60 T5 GT 205K+ miles OWNED SINCE DAY ONE - Bilstein Sport + TME, ipd sway bar + endlinks, UR chassis braces (upper F+R), Powerslot /Akebono pads, Snabb Intake, iMIV Original engine, transmission replaced at 78k miles
      Wife -'13 C30 T5 R-Design 63k+ miles Dad - '98 S70 T5 205k + miles, Bilstein TCs, IPD HD rear springs, SAS delete Mom -'10 S80 V8 Executive Sis - '02 S80 T6 Backup car -'13 S60 T5 (Not as fun as my '01)
      Past
      '95 850 '92 960
    7. #5
      Oct 2012
      Kansas City
      Scottish will probably flay me for this, but I have a set of Delphi on my C70 from 3 years ago, and haven't had problems with them...
      They were cheap; currently 27/each on Amazon. (For reference the Bosch are 47 on Amazon.)
      And then the warranties are 1 year for Bosch and 3 for Delphi...
      2000 C70 HPT 5 spd; ~140k miles IPD high-flow air filter; Snaab high-flow Intake; Snaab short throw shifter.
      2004 V70 AWD ~155k 16T; Snaab high-flow intake; Snabb downpipe; ARD tune
    8. #6
      Oct 2014
      Boston
      Original coils (Bosch) lasted 14 years and 220k miles for me.
    9. #7
      Member TGO's Avatar
      Mar 2007
      Staten Island NY
      Quote Originally Posted by wtyrrel View Post
      I have Delphi as well. No bubbles no troubles. I never had any problem with Delphi as a brand.
      2002 XC70 2.4T - "Orca"
      White/Sand(Beige)
    10. Remove Advertisements
    Similar Threads
    1. Replies: 2
      Last Post: 09-26-2018, 12:06 PM
    2. weak ignition problems... coil replacement recommendations for electronic ignition
      By dissonant in forum P1800, 1800 & 1800ES (1959-1973)
      Last Post: 06-17-2015, 09:24 PM
    3. Ignition coil question
      By 707V70T5 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 05-07-2015, 12:55 PM
    4. Ignition Coil Question.....
      By rev dennis in forum C70 (1998-2004)
      Last Post: 04-28-2011, 05:28 PM
    5. Used 850/X70 ignition coil and new coil wire
      By heavyiron in forum FWD & AWD Parts For Sale
      Last Post: 02-21-2009, 10:44 AM
