Replace SIM
    Results 1 to 16 of 16
    Thread: Replace SIM
      Junior Member TrnNY's Avatar
      Mar 2018
      Replace SIM
      I'd like to replace the AT&T SIM with a Project Fi data SIM. Couple questions 1. anyone knows if Project Fi SIM works 2. where is the SIM
      Junior Member schmitty8225's Avatar
      Jun 2019
      Orlando, Fl
      Someone did it work a different model. Don't remember the outcome. Use the search to find it.
      Sent from my MHA-L29 using Tapatalk
      2020 V60 T5 Inscription Fusion Red Luxury and Advanced Package
      Member
      Dec 2017
      PNW
      Most GSM SIM should just work. Both AT&T and TMobile SIM work for me. Project Fi should be no problem.
      For location of the SIM slot, I can't say about XC40. It should be described in the user manual. You can search online for a PDF version.
      Rolling, Fusion Red - 2018 XC60 - T8
      Running to retire, 2000 V70XC 236+k miles
      SwedeSpeed.com
      Junior Member joebxr's Avatar
      Mar 2018
    7. #5
      Mar 2018
      Thx 👍
    8. #6
      Mar 2018
      So that looks like where the spare is located
    9. #7
      Mar 2018
      real world pics
    10. #8
      Member
      Dec 2017
      PNW
      Great pics. I wish they put the SIM slot in glove box... It is better in trunk but still need to lift the cargo cover. And on XC60 I need a small screwdriver to open the tiny cover.
    11. #9
      Jun 2019
      Orlando, Fl
      In the v60 it's underneath the glove box.
    12. #10
      Member
      Dec 2017
      PNW
      Quote Originally Posted by schmitty8225 View Post
      yeh, and still need a small screwdriver...
    13. #11
      Apr 2018
      Huntington, NY
      2019 XC40 Momentum black
    14. #12
      Jun 2017
      VA
      Quote Originally Posted by joebxr View Post
      This says "Vehicles with Volvo on Call, it is possible to establish an Internet connection via the vehicle modem and a personal SIM card. When the vehicle is connected using the integrated modem, the Volvo On Call services will use this connection"
      2 questions for you all.
      1. is the sim tray unlocked, as in can I put an international SIM in it and use the data connection overseas?
      2. If yes to the first questions does the first part mean Volvo On Call will try to use the Personal SIM data connection first and if that is unavailable it will default to the integrated one? (thus meaning I'd be able to use VOC overseas with a International data connection, OR a US Sim card where the data works overseas?)
    15. #13
      Member
      Dec 2017
      PNW
      Quote Originally Posted by DjRashonal View Post
      1. Yes, it is unlocked. However the modem is GSM and use frequency bands of USA carriers. Your international SIM has to be GSM and match the carries there.
      2. VoC traffic will always go through VOC SIM I think. Not sure if it will use the personal SIM ever. My hunch is it will if VOC SIM doesn't work in the region. Also US SIM needs data roaming service to be used overseas.
    16. #14
      Apr 2018
      Huntington, NY
      I called Verizon about getting a sim card and they won't issue one for the car. Only a device they support. The guys over the phone seemed shocked when I said it was for my car.
      Kris
    17. #15
      Jun 2017
      VA
      Quote Originally Posted by FusionRedXC60 View Post
      That's good to know! Most carriers in Germany are GSM and use pretty much the same LTE bands as the states. I think there are 3 or 4 that are different. I also have a U.S. T-mobile line that has data roaming built in. This would be an interesting experiment...
    18. #16
      Awaiting Approval
      Jan 2020
      Quote Originally Posted by TrnNY View Post
      Google Fi SIM works, but I needed an adapter to make it fit.
    19. Remove Advertisements
    Similar Threads
    1. swap the ATT SIM out and replace with T-mobile SIM?
      By sleon in forum XC60 (SPA: 2018- )
      Last Post: 08-14-2019, 10:09 PM
    2. Prepaid SIM to replace ATT
      By mjkpreno in forum XC90 (SPA: 2016 - )
      Last Post: 03-19-2018, 12:10 PM
    3. Replies: 2
      Last Post: 01-22-2007, 02:58 PM
    4. help with sim card in phone needed desperately
      By apetro08 in forum S80 (1998-2006)
      Last Post: 11-28-2006, 09:51 AM
    5. Integated GSM Phone - Problem with SIM
      By Danny in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 10-26-2003, 01:48 PM
