Gas in Oil y’all.
    Results 1 to 3 of 3
      Junior Member ClarenceRay's Avatar
      Dec 2018
      Cincinnati
      Gas in Oil y’all.
      During my last routine oil change, I noticed a significantly potent fuel/solvent smell in my oil. I run Mobil1 10W-30 Full Synthetic in my ‘06 V50 T5. This was paired with a sharp decrease in fuel economy.
      I went ahead and changed my Fuel Rail Pressure Sensor, and checked back on the oil 2 weeks later. It’s still got gas in it, and it’s an orangey color.
      Checked it in VIDA, and all pressures are good, and there’s no codes for the fuel system.
      Dropped the car off at Volvo last week, and they couldn’t find anything wrong. Has anyone had any issues like this before? It’s not misfiring or roughing significantly rough. It does idle a bit rough, but paired with the ridiculous fuel usage, that’s about it.
      Any ideas? My next move is to replace all of the injectors.
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      Possible fuel injector sticking open. Fuel continues to seep into the cylinder when the engine is off and past the rings into the oil.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
      Dec 2018
      Cincinnati
      If I had an injector sticking open when off, could it still behave normally while the engine is running?
    Similar Threads
    1. Bad Gas Mileage and Smell Gas
      By jrick212 in forum R Forum (2004-2007)
      Last Post: 05-04-2012, 08:30 AM
    2. Gas door won't open, manual switch does not work, gas light on!!!
      By lowenhart in forum R Forum (2004-2007)
      Last Post: 04-07-2009, 02:43 AM
    3. GAS OUT - Don't pump gas on May 15th, 2007
      By shuttlecommander in forum Off Topic Forum
      Last Post: 05-14-2007, 10:59 AM
    4. Replies: 13
      Last Post: 11-02-2006, 03:51 PM
    5. Gas tank, Gas Gauge and Mileage
      By rs4-380 in forum 240, 242, 244 & 245 (1974-1993)
      Last Post: 01-21-2006, 12:37 AM
