New Sensus update causing power steering error
    Results 1 to 6 of 6
      Jul 2016
      I just had the newest Sensus updated and one week into driving I get this power steering error message. You think they'd test this type of stuff in the QA process. Almost every time I get a Sensus update, it causes a new and erroneous error message. Gosh Volvo...
      Sent from my SM-N975U using Tapatalk
      Jul 2017
      Quote Originally Posted by dealcatcher View Post
      You could have a bad battery. Lots of posts here about this (happened to me too). Get it checked out at the dealer before you're stranded with something worse than an error message.
      2018 XC90 Inscription / Air Suspension / B & W / 21" OEM Wheels
      Jan 2016
      NoVA
      Coincidence?
      2018 V90 T5 R Design FWD | Bursting Blue / Charcoal, Full Napa Leather | 20" R Design Diamond Cut wheels | Convenience Package | Laminated Glass | Heated Seats/Steering Wheel | HUD | Powered Load Cover | Mud Flaps | Rubber Floor Mats | Polestar Optimization
      SwedeSpeed.com
      Feb 2016
      Maryland
      So I got the my last update in Oct 2019 which I guess the next update was in Nov. if I park the car and get out, go to the mailbox the car, even with key left in car I get an error message key not found. Both keys do this. No battery warning. If I stop the car then I have to lock and unlock to start it. Anyone else have this issue. Should I get a software upgrade or is that going to give me a power steering issue with my 2016 XC90 T8
    7. #5
      Jan 2016
      NoVA
      Get the software update and don't let them charge you for it.
    8. #6
      Feb 2016
      Maryland
      Quote Originally Posted by masvolvo View Post
      Called the Dealer, turns out it was my new Quick charger usb that I plugged into the 12 volt next to the key sensor. It was on sale for $8 on Amazon, must be poorly made. Anyway I went back to my older usb charger and the problem went away. I did not go in to get the software upgrade.
    9. Remove Advertisements
    Similar Threads
    1. I glitched Pilot Assist causing a power steering issue
      By mgmiller in forum S60 & V60, V60CC (SPA: 2019- )
      Last Post: 08-21-2019, 05:47 PM
    2. DICE ~ Diagnostics tab causing handler error
      By ukinne in forum OBD, CANBUS & Engine Management
      Last Post: 05-16-2016, 04:39 PM
    3. Volvo v40 sensus connect nav update error
      By samuka1984 in forum V40 (2013-2018)
      Last Post: 07-22-2015, 02:51 PM
    4. Volvo S60R Cold Air Intake and ECM upgrade causing engine light error.
      By atomicone in forum General Volvo Discussions
      Last Post: 02-05-2005, 12:12 PM
    5. Replies: 5
      Last Post: 06-16-2004, 10:40 AM
