Engine swap from T5 to T6
    Results 1 to 13 of 13
      Jan 2020
      California
      I am very curious if anyone knows how easy it would be to swap out the engine from my fwd 2012 t5 for a t6. If possible would it just be a plug and play or would I need to replace other components like ecu and fuel pump. I am only considering this as It appears my engine has ceased but we are still sorting through some other minor possibilities, but if worst comes to worst and I do have to replace the engine I’d be interested in swapping it for the bigger T6.
      Feb 2015
      I'll keep it short. No.
      2015 V60 R-Design - Onyx Black Metallic / Off Black
      2004 Mazda 6s Touring - 3.0 V6 / Manual
      2008 Suzuki SV650 - Pearl Novelty Black
      2002 SVT Focus Turbo - Dead and gone
      Apr 2014
      You need everything from the donor so, so much so that you just use the donor car.
      Not possible to swap, especially not in CA.
      SwedeSpeed.com
      Member
      Jun 2012
      Pittsburgh, PA
      One would think since it's the same chassis and same transmission. But then again, nop.
      After seeing how swapping simple stuff like the instrument cluster can become, how shall I say, ... a cluster, an engine swap would be very impractical.
      Gone are the days when you can drop a V8 in a Volvo (as in the 240).
      2012 S60 T5 Savile Gray/Beachwood
    7. #5
      Jan 2020
      California
      Well looks like to rebuilding or buying the same engine it is, I appreciate the feedback and will probably keep you guys posted on how the whole build is going.
    8. #6
      Feb 2015
      Quote Originally Posted by Deayeego View Post
      Maybe upgrade it a bit!
    9. #7
      Member KCCM's Avatar
      Aug 2011
      Toronto, Canada
      Fix & ditch your 2012 T5 and upgrade to a used 2015+ T6 AWD R-Design, which is probably one of the best engine & drivetrain combinations Volvo has ever produced.
      KECA Kombi - Now '16 V60 T6 AWD R-Design - Just a K&N filter so far, but love the PoleStar tune.
    10. #8
      Mar 2016
      Quote Originally Posted by KCCM View Post
      Better than the 3.0 Polestar ?
    11. #9
      Quote Originally Posted by grahamR View Post
      Literally the same engine and transmission albeit with a slightly smaller turbo and tuned to produce slightly lower output. Real world straight line performance is very similar. I’m willing to bet my lightly tuned T6 is quicker than a stock 3.0T P* car. The price difference is significant and not necessarily worth the huge jump in cost for the real P* version.
      2011 S60 T6 with Polestar tune+TDI-Tuning : KW V3 coilovers : DO88 fmic : Ferrita downpipe : Powerflex "race" torque mount insert
      12.99 at 109mph
    12. #10
      Feb 2017
      NJ
      It's a thought I've had many a time in my oil guzzling T5 which should have included a funnel in the trunk. No spare donut was insult to injury...a repair can and no back-up cam for a $40,000 safe car. At least I've got my comfy seat and safety cage.
      2012 S60 T5 FWD & 2013 XC90 AWD
    13. #11
      Aug 2011
      Toronto, Canada
      Quote Originally Posted by Bunnspeed View Post
      Yes, unless you track your P* (and you really should have a much more highly tuned car if you do) the R-Design is just a better and more satisfying car for most driving.
      Going for a PoleStar 2 next, which I have great hopes for.
    14. #12
      Aug 2011
      Toronto, Canada
      Quote Originally Posted by Highwayman View Post
      Loaded V60 RD has all the toys and you can fit a donut in the back if you like.
      Too bad about the oil guzzling. Previous Volvo was an ‘07 V70R which still used less than a litre of synthetic between changes when I sold it with 335k km on the odometer. It was tuned and nominally had about the same power/weight, but our ‘16 V60RD just does everything better, quicker and smoother.
      As I said, looking forward to our P* 2 on order, which promises to be quicker, smoother and overall better again - no engine means no (premium) gasoline, no regular maintenance and a little greener-than-thou street cred
    15. #13
      Feb 2017
      NJ
      Actually it's ironic you posted your previous ride being the V70R, I've looked at some and wondered if it's really a trade down from my 2012 T5. Some low mileage V70 ones out there can be had on the cheap. Having the R or Polestar is great, can't argue that but I'll take a stock one at this point.
      Tired of going into Advance Auto and buying the 5 Quart Jugs.
      May change my T5 badge to 5 QT ...lol
    16. Remove Advertisements
    Similar Threads
    1. My 02 V70XC engine swap/trans swap for 2004 C70
      By wrcware in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 03-25-2018, 01:44 PM
    2. 2003 xc90 t6 engine swap can i do this ??? S80 t6
      By TaffyNZ in forum XC90 (2003 - 2014)
      Last Post: 04-22-2017, 10:47 PM
    3. Xc90 T6 engine swap to a T5 2.5
      Last Post: 03-30-2017, 07:36 PM
    4. Difference between XC90 T6 engine and the S80 T6 engine ?
      By barrysharp in forum XC90 (2003 - 2014)
      Last Post: 08-21-2003, 06:32 AM
