B5244T5 (T5 engine) To shim or not to shim?
    Results 1 to 18 of 18
      Apr 2007
      Nashville
      Looking for some feedback here. I've got the B5244T5 (2.4L T5 engine) going into the VR, but is it totally necessary to shim or strong enough as is?
      I'm going to be running the IPD 4T4 turbo, full bolt ons and meth. Don't want to pull it apart if it's strong enough already.
      04 V70R Flash Green/Atacama6MT
      Junior Member stomish's Avatar
      Jun 2016
      South Jersey
      Iíve been told you donít *need* to, but itís definitely worth doing while youíre in there.
      completely unable to go through drive thrus
      Had to shorten my flair because it was becoming disgustingly long
      2004 M66 Passion Red V70R // StevO tuned, Rolling Motors built B5244T5 w/ Spec lightweight flywheel, stage 1 head, custom catted/catless DP plus more
      2004 M66 Electric Silver S60R (Sold) // 2004 AW-55 XC70 // 1996 AW72L 965 (Sold) // 1987 AW77 745 Turbo (Sold)
      1993 AW70 245 Wagon(with only 97k!!) (Sold) // 1988 AW70 245 Wagon (Sold) // 1987 M47 244 Sedan (Sold)
      1997 M56 850 Estate (Sold) // 1979 BW35 242DL (Sold) // 1996 AW30-43 960 Sedan (Sold) // 2007 AW55 XC70 Adventure package (Sold)
      2007 AW55 XC70 Adventure package parts car (Parted out) // 1996 AW50-42LE 850R Estate w/ 16T and Blues (Sold)
      1993 M47 245 Slicktop (Sold) // 1986 M46 245 Slicctop "Butter" // 1994 945 Turbo (Sold) // 2005 M66 Passion Red S60R // 2005 M66 Electric Silver S60R
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      No. Pointless. 81mm bore is more than strong enough and thereís no reason to split the block.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      SwedeSpeed.com
      Jan 2016
      Nashville
      I have no idea, but I definitely want a ride once itís done!
    7. #5
      Member
      Jun 2011
      Congo
      Quote Originally Posted by Ihatespeedbumps View Post
      it's not pointless as some that never pushed high hp out of their 81mm bores are so quick to give advice...even with 400 at wheels you will see distortion between the sleeves in a 81mm bore so at 600 at the wheels i would not chance it but yes it is almost unheard of to crack them vs. 83mm bore...if you have the head off = yes , if not = i would not shim for less than 500 and more than 500 i would remove the head.
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
    8. #6
      Member HunterBD's Avatar
      Jun 2011
      Bryn Mawr
      I was waiting for dougy to chime in. He would know. I can see where it is beneficial to shimming the block in high output engine builds. IMO if I had the head off I would shim it for future possible power, even if I had 400hp. Once you start adding power you may want more power...then you have to start all over again.
      05 VR GT Titanium Grey/Nordakp, sunroof, Winter Package, Premium sound with Volvo Sub. VST rear brace, Ultra Racing front strut brace.
    9. #7
      Apr 2007
      Nashville
      Quote Originally Posted by tshiv View Post
      Of course!
      Quote Originally Posted by dougy View Post
      Realistically I'm never going to go larger than the 4T4 turbo which isn't going to make more than 500HP. We can't all be like you changing turbo setups like underwear
      Asking the question because I want a very reliable setup, but I'm also balancing my procrastination level. I've had this B5244T5 on the engine stand for almost 2 years.
    10. #8
      Junior Member Saffron-R's Avatar
      Aug 2008
      Portland, Oregon
      I cracked a sleeve on a built but un-shimmed B5244T5 with that 4T4 turbo. Literally, THAT turbo ( I sold this to you).
      Absolutely, unequivocally, shim the block with any larger-than-stock frame turbo, or even a hybrid K24 for that matter. Especially if you have the motor on a stand.
      I speak from experience. I am currently on engine #5. Iíve had MTE/ipd tunes, and more recently running VAST tunes on my built Ď98 V70R.
      Best of luck, and youíre going to love the 4T4. I did.
      1998 V70R, M58 AWD manual, Built B5244T5 (Wiseco 81.5, RSI Rods), Garrett GTX3071R gen 2 .82ar (IWG), VAST custom tubular exhaust manifold and downpipe, Sachs 707pp/ R clutch,VAST COP E85 tune with dual VVT control, 3.25Ē ID MAF housing and custom intake, na TB, DW300, DW 950ccís, ipd diverter, ipd intercooler, DO88 aluminum radiator, Magnaflow exhaust, Kaplhenke dbl adjustable front&rear coilovers, Kaplehenke delrin subframe bushings, ipd sways/strut brace, Porsche BBK front, rear '00 VR rotors/calipers, 17Ē BBS RGRís, Jewels.
      485awhp, 598awtq on Mustang dyno
    11. #9
      Member IwantaS60R's Avatar
      Nov 2003
      Jersey City, NJ
      Quote Originally Posted by Saffron-R View Post
      Hey Saffron-R, quick question....how much kg/h were you able to flow through that 4T4? I've never seen actual kg/h numbers for that turbo.
      TIA
      HERS - 2007 XC90 3.2
      MINE - 2004 S60R : List of modifications - PhMIC, EST grille, K&N filter w/velocity stack, Eibach springs, iPd rear camber bushings, ELEVATE front and rear sways, Powerflex front LCA bushings, superflex rear LCA bushings, Turbo back exhaust, Aquamist, TWM short shifter, TWM shift knob (Big Type R), Black Forgestar F14 18x8.5 wheels, roof spoiler
    12. #10
      Aug 2008
      Portland, Oregon
      Quote Originally Posted by IwantaS60R View Post
      TIA
      Oof, I used to know that information off the top of my head. I think I have the numbers in an email thread with my tuner, Iíll see if I can dig it up later. I know itís not much more that a K24, however. Despite the rather disappointing flow rate, the turbo is a real nice improvement over K24- only slightly laggier and so much more usable power over the RPM range- particularly up top. Great turbo, and unlike the hybrid K24ís out there that have simply been machined to accept larger wheels, this 4T4 is cast and much more robust- should have better long term durability. PM me with any other questions so we donít muddy this thread.
    13. #11
      Nov 2003
      Jersey City, NJ
      thanks for the reply man .....to keep it on topic, I would also recommend shimming the motor especially given you have it out of the car.
    14. #12
      Member
      Jun 2011
      Congo
      If you cracked 81 mm bore under 500 horsepower to Wheels your tuning was not right is why and also if you going to make statements/claim you crack 81mm, show documentation/ pictures to support your statement...and if it was built and you did not shim it well that's just dumb cuz you were there
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
    15. #13
      Aug 2008
      Portland, Oregon
      Sorry, no pictures, just a hole in my bank account to prove it. Maybe a tuning problem, which is why I donít let Marco (MTE/ iPd) tune my car anymore. MTE tunes fragged 3 of my motors. This is why Iíve been with VAST.
      Agreed, dumb to have not shimmed the block when I was in there. Live and learn, and precisely why I chose to participate in this thread and imparting my experiences.
      I hope youíre doing super, Dougy, and happy new year. Thanks for giving me guff, always appreciated.
    16. #14
      Member
      Jun 2011
      Congo
      Aaron is the man! you are in good hands...im 99% sure whatever happened to it was improper tuning.
      happy new year to you saffron and sorry if i've been hard on you here and there.
      1997 Toyota Avalon
      2000 Mercedes ML320
      2005 XCR90
      2006 C70
    17. #15
      Apr 2007
      Nashville
      Thanks for the responses guys, I think I'm going to go the shim route.
    18. #16
      Member CapeMayXC70's Avatar
      Sep 2015
      South Jersey
      I would listen and takes Doug's advise
      05 XC70R Ice White
      06 V70R GT TiGrey/Gobi
      Sold & missed: 05 V70R M66 Saffhire Black/Nordkap
    19. #17
      Jun 2011
      Bryn Mawr
      agree. Do it right the first time.
    20. #18
      Senior Member JaredR's Avatar
      Jan 2014
      Boston, MA
      The failure is in tension not compression..........
      1995 850 T-5R Estate. AW50-42LE. Cream Yellow/Graphite. 296k.
      1997 850R Estate. RN/M66D. Bright Red/Graphite. 270k.
      2007 S60 T5. M66W. Black Sapphire/Arena. 136k.
      Past: |1997 855R. Bright Red/Light Beige. AW50-42LE. Totaled by wayward construction equipment. || 1996 854R. Black Stone/Graphite. AW50-42LE. Parts car || 1995 854 TURBO. Polar White/Tan. AW50-42LE. Parts car. |
      Dad: 1997 V70 T5 SE. AW50-42LE. Frost Green/Oak. 212k.Mom: NEW! 1999 S70 GLT Pewter/Oak. 100k. Past: 2004 V70 NA. AW55-50SN Ruby Red/Tan 269k.
    21. Remove Advertisements
    Similar Threads
    1. B5244T5 2005 s60/v70 T5 or R engine upgrade
      By 91shelby in forum FWD & AWD Parts For Sale
      Last Post: 11-20-2018, 12:54 PM
    2. Heads up - B5244T5 LKQ Nashville (05+ T5 engine)
      By Ihatespeedbumps in forum R Forum (2004-2007)
      Last Post: 07-26-2018, 10:10 AM
    3. WTB B5244T5 2.4L S60 T5 Engine
      By robspec in forum Want Ads
      Last Post: 04-09-2018, 05:39 PM
    4. B5244t5 2.4 engine
      By Wild_woodliff in forum Want Ads
      Last Post: 08-19-2017, 05:46 PM
    5. COMPLETE ENGINE: B5244T5. (2005+ S60/V70 T5)
      By ArtVandelay0023 in forum Want Ads
      Last Post: 12-08-2006, 08:28 AM
