2005 volvo s40 dead
    Results 1 to 5 of 5
      Awaiting Approval
      Jan 2020
      2005 volvo s40 dead
      i was driving my 2005 volvo s40 on the freeway and it just died suddenly. im pretty sure i heard a click right when it died. the lights and everything seemed to be working fine but it died. so i pull over and it wont start... it doesnt even click when i turn the key. but there is a message on the dash that says "anti-skid service required"... so i took it to a mechanic and they want 500 to replace the starter. would a bad starter make it die like that on the freeway?
      Junior Member lunalolvo's Avatar
      Nov 2016
      Jersey
      Quote Originally Posted by clarenk View Post
      Sounds like nonsense to me, can't imagine any way a starter would kill the engine on the highway. If it could prevent the engine from turning, it'd have to be seized in the "start" position meshing with the ring gear, which I've only seen happen after a car has been left to rot and rust together for years on end, and even so it wouldn't have started in the first place.
      I'd guess it's an electrical issue - the battery and the CEM connections in the footwell are common areas to check to start debugging.
      Member jondevieonS40's Avatar
      Oct 2011
      ABQ New Mexico
      Clean and tighten your battery connections, then check if your battery holds a charge at a local Autozone, i know its hard with the car not moving but that might save you $500.
      2008 S40 T5 AWD ("Shadow") |ELEVATE 3" Intake, 2.5" Charge Pipe, Intercooler, Torque Mount, ECU Mount, TCV, Turbosmart CBV, Turbosmart Actuator, stage 3 APC Tune, 3 Stickers (5HP)ea||ClockWorkCalibrations Custom 3" Exhaust||EuroSportTuning 3" downpipe.||CF Cone Filter||De-Badged||custom Mesh Grill||Intercooler Cut out||Porsche 911 Throttle body upgrade||18" Enkie PDC Wheels wrapped in 225/45/18 Sentury UHP||M3 Spoiler|| 8k Morimoto HID Kit|| White LED Fog,City,trunk light|"embody God, then go crazy"
      SwedeSpeed.com
      Jan 2014
      Takoma Park, MD
      What does VIDA think?
      I had something like this on startup after fuelling on a roadtrip. In my case, my V50 decided that it was in "limp mode" 250 miles from home. Unhooking the battery for ~5 mins & carefully re-powering persuaded the CEM that things weren't that bad, and normal operation resumed.
      Mark
      "New-to-me" V50 Back from the dead.
    7. #5
      Sep 2015
      Quote Originally Posted by jondevieonS40 View Post
      Agreed. Doubt it is the start, check the battery first and then the alternator. Just experienced this with our 2004.5 S40 in December as it flat out died with similar symptoms. We initiallaly thought it was battery, replaced battery, worked for a day. Then same symptoms. Turned out to be bad alternator.
    8. Remove Advertisements
    Similar Threads
    1. Wanted: 240 *** 240 *** 240 *** 240 *** 240 *** 240
      By lovemyvolvo in forum Want Ads
      Last Post: 02-19-2014, 10:08 PM
    2. DEAD DEAD DEAD
      By Kodabear in forum XC90 (2003 - 2014)
      Last Post: 04-30-2008, 04:05 PM
    3. HELP!! My R is dead (mostly dead)
      By partridge in forum R Forum (2004-2007)
      Last Post: 09-15-2007, 03:21 PM
    4. Replies: 26
      Last Post: 12-14-2006, 12:46 PM
    5. Dead Light Warning but no dead lights?
      By yieldsign2 in forum 740 & 760 (1982-1992)
      Last Post: 09-04-2005, 01:05 AM
