2013 XC70 - Rear Windshield Washer
    Results 1 to 5 of 5
      Jun 2013
      Question 2013 XC70 - Rear Windshield Washer
      So our rear windshield washer no longer pumps fluid.
      It started after we had some hail damage repair, and complained to the shop. They diagnosed it as the pump was going, since they were not responsible, said I would fix it later.
      Well the car was in for some other repairs and they swapped out the pump for us, the 2-in-1 that goes with the front pump.
      Well, it still doesn’t work.
      Is there something else I should be checking to help narrow down what is going on? Is there another pump somewhere else?
      I am 99% certain they dropped the headliner to fix the hail repair, not sure if there is anything routed in the roof that deals with that.
      Any help or insight is appreciated!
      Sep 2018
      First, use a light gauge pin, and ream out the spray orifices at the top of the tailgate. If that doesn't work, you may want to pull back the headliner and check to see if the rubber tube got pinched off somewhere.
      Nov 2016
      Wash. County, Oregon, USA
      Quote Originally Posted by pbierre View Post
      One would hope it isn't the 3rd option... that the rear hose has failed and is pumping fluid somewhere.
      Is the sound of the pump the same or nearly so in front vs rear operation? Or does the rear operation sound a bit, er ... constipated, which would support pbierre's diagnosis?
      Or the 4th possibility: could the rear hose be frozen?
      Good luck getting it sorted.
      2016 XC70 2.5L T5 AWD, Platinum, Seashell/black, ipd rear bar, Curt hitch and wiring
      Previous Volvos: '16 V60CC, ours; 7? 245DL & '6? 145DL, hers; '68 122S Wagon, his.
      Non-Volvos previously owned: waaay too many to list here.
      SwedeSpeed.com
      Jun 2013
      It wasn’t clogged. Also the check-valve in the rear is fine. My guess is there is a check-valve closer to the pump that is clogged or broken.
      Any idea where that is?
    7. #5
      Jun 2013
      Quote Originally Posted by halfast3 View Post
      Well the pump sounds the same. I pulled off the rear trim on the lift gate and the check valve is fine there. I am guessing there is another check valve somewhere closer to the pump.
      Also it is not leaking.
      Do you have any idea if you can get access to the washer pump area if you pull the wheel and then pull off the mud guard that is there? If it means pulling the bumper I will just take it in.
    8. Remove Advertisements
    Similar Threads
    1. Leaking rear windshield washer fluid?
      By bren213 in forum XC90 (SPA: 2016 - )
      Last Post: 11-29-2017, 07:44 AM
    2. 2013 XC70 original windshield leak (45K miles) in car wash (Warrantied?)
      By viaVolvo in forum V70 & XC70 (2008 - 2016)
      Last Post: 12-01-2016, 08:33 AM
    3. P4 xc70 p4 xc70 p4 xc70 p4 xc70 p4 xc70
      By CrossingCountries in forum V70 & XC70 (2008 - 2016)
      Last Post: 10-09-2015, 11:21 AM
    4. 2013 XC60R vs 2013 XC70 T6
      By 3g3t7i in forum General FWD & AWD
      Last Post: 07-02-2013, 09:29 AM
    5. Rear Windshield Washer
      By castconcrete in forum S70, V70 & V70XC (1998-2000)
      Last Post: 07-04-2009, 11:44 AM
