tailgate LED retrofit
    Results 1 to 5 of 5
      Member Ocean Racer's Avatar
      Oct 2009
      Melbourne / Australia
      After lots of thread searching, I need some help.
      Am after a suitable solution to replace the tailgate / luggage compartment LED fitting with an improved LED retrofit.
      The OEM fitting has a pathetic dull single LED fixed to a all-in-one circuit board.
      XC60 2014/2015 build.
      Anyone have any luck here?
      02 XC70 R PROJECT TERRÄNGKÖRNING LANDVAGN
      04 V70R PROJECT LANDBARGE
      11 XC60 R-DESIGN PROJECT HEICO
      Junior Member ckmack's Avatar
      Mar 2015
      Southern Maine
      I'm also interested. Just swapped the rest of mine to LED in my V60, disappointed in the cargo area lights
      Daily Driver: 2017 V60 T6 R-Design Bursting Blue / Black, 41k, "Bertie"
      Garage Queen: 1995 850 T-5R sedan Cream Yellow / Black, 97k, "Daisy"
      Garage Queen: 1995 850 T-5R estate Cream Yellow / Black, 287k, "Daisy2"
      Past: 2005 V70R Flash Green / Nordkap, 86k, "Flash"
      Past: 2005 S60R Black Sapphire / Nordkap, 88k, "Peggy"
      Past: 2000 V70R Laser Blue / Black, 174k, "Vicky"
      Past: 2000 S70 GLT SE Moondust / Beige, 175k, "Sandy"
      Past: 2013 S60 T6 R-Design Rebel Blue / Black, 88k, "Roxy"
      Past :2006 XC70 AWD Willow Green / Beige, 148k, "XC"
      Jan 2020
      Quote Originally Posted by ckmack View Post
      Same for me too, so I have light bought 4x 12-24v LED flush bullet lights to install in the tailgate and side panels. Plan is for two in the tailgate and two side panels run off the existing 12v interior tailgate active light. I'll let you know how I get on.
      So I've installed the lights now and am very very happy with the result. I bought 10x led bullet light form amazon, link: https://www.amazon.co.uk/dp/B075L9S1...395841_TE_dp_1
      Installation was very straight forward, I was pushed for time so may install two more lights linked to this chain around the wheel well area of the boot.
      Link to photos: https://www.icloud.com/sharedalbum/#B0ZJ8GySPJEKK6Y
      Justin
      SwedeSpeed.com
      Feb 2019
      I have a pretty powerful 41mm LED festoon bulb which gets mush better results compared to a regular bulb.
      A very clean look would be to grab another stock bulb socket and mount it symmetrically on the other side of the hatch and wire them together. All that would be required would be to cut the trim panel to the same size as the other hole. Part number for the lamp holder is 30754443. Only $15ish...
    7. #5
      Junior Member TheStillMan's Avatar
      Jun 2017
      Ohio
      Quote Originally Posted by Glennda5id View Post
      OP is talking about the ones that have a soldered LED light, not the festoon bulbs like the early models have.
      2010 XC60 T6 Sapphire Black Metallic (TFT DIM retrofit, DynoMax muffler, Eibach lowering springs & Koni struts, HardRace adjustable rear toe arms)
      2004 Subaru Legacy Outback wagon 2.5 White Frost Pearl (Also mine) | 2011 Chevy Equinox LT1 AWD Olympic White (Hers)
    8. Remove Advertisements
    Similar Threads
    1. Is a Thor LED Headlight Retrofit Easy?
      By Ziege in forum XC90 (SPA: 2016 - )
      Last Post: 12-10-2017, 10:11 PM
    2. Replies: 3
      Last Post: 10-21-2014, 06:57 PM
    3. Full retrofit LED Fogs...
      By The Driver in forum R Forum (2004-2007)
      Last Post: 11-06-2013, 08:12 PM
    4. Replies: 8
      Last Post: 06-05-2013, 05:32 PM
    5. LED retrofit bulbs for switches
      By Prospero in forum 850 (1993-1997)
      Last Post: 01-28-2001, 07:06 PM
