Locking Issue
    Results 1 to 7 of 7
    Thread: Locking Issue
      Sep 2017
      Syracuse, NY
      Locking Issue
      I tried locking my car with my key fob. I didn't hear the beeps st all like it usually does when it confirms it is locked. So I tried to open the doors (after placing the keys far enough away to not activate the keyless entry). All were locked, except the rear driver door unlocked and the alarm started going off. Anyone know what's going on or have had this issue? Thanks.
      Sent from my SM-G975U using Tapatalk
      2015 Crystal White Pearl S60 T6 R-Design
      KPAX Catback Exhaust
      Powerflex Torque Rod Insert
      IPD Rear Sway Bar and Endlinks
      18" Polestar Replicas
      I have the same issue. The only thing I've found is a small hole above the latch on the door. I stick my house key in, turn it clockwise until it clicks, sometimes I have to do it on each door, and then the lights will flash and the beep occurs. It doesn't fix it permanently but it does fix it for a while.
      Jun 2012
      Pittsburgh, PA
      What is mentioned above is not a fix. It's just a way to lock the door when the electric lock does not work. It's a fail safe way if you will.
      Anyway, those locks are known to go bad with use. You can change them yourself to the tune of about $180 or so for the part plus your time and effort. Or, of course, you can have it done by the dealer.
      At this point I'd recommend doing nothing and living with it. These locks, on all 4 doors, are subject to a recall by Volvo. Wait till you get the letter from the dealer.
      Sent from my ASUS_Z017DA using Tapatalk
      2012 S60 T5 Savile Gray/Beachwood
      Junior Member Sysyphus61's Avatar
      Dec 2016
      Suburban Philadelphia
      Drowning my flakey lock mechanism in WD40 has fixed it for about eight months and counting
      2009 C70 T5, Celestial Blue 130k
      2011 S60 T6 AWD Caspian Blue
      Mar 2011
      Arlington, VA
      Quote Originally Posted by Almaz View Post
      Are the electrical actuators being replaced as well with this recall? I thought it was just the latch mechanism?
      2012 S60 T5 - Flamenco Red, Soft/Sandstone Beige, Climate, Premium, Multimedia, Xenons, BLIS, PCC, Park Assist, Urbane Wood, TFT Retrofit
      Jun 2012
      Pittsburgh, PA
      The latch and actuator are all in one unit so yes, both will be replaced.
      WD40 would be worth a try. It didn't work for me though.
      Aug 2019
      Fort Lauderdale, FL
      Welcome to the party! It seems like we aren't alone with this issue. I have a 2012 S60 T5 and both of my rear doors have gone bad. Luckily there is a recall which affects 2011-2017 S60/V60s which replaces the latch. My guess is that Volvo made the latches very poorly and as a result they seem to fail after 5 years. I did temporary fix it by putting WD40 inside the actuator but after a few days the issue arouse again.
      2012 Volvo S60 T5 | Caspian Blue Metallic | Premium Package | Climate Package | Multimedia Package | BLIS
    10. Remove Advertisements
    1. Car locking but not locking?
      By UnknownUser in forum XC90 (SPA: 2016 - )
      Last Post: 09-20-2019, 08:00 PM
    2. Replies: 2
      Last Post: 08-29-2017, 08:40 PM
    3. Door Locking/Unlocking Issue After May Update
      By msai_kris in forum XC90 (SPA: 2016 - )
      Last Post: 08-22-2016, 11:30 AM
    4. Central Locking issue
      By Bachman in forum 850 (1993-1997)
      Last Post: 01-10-2015, 01:23 PM
    5. Replies: 24
      Last Post: 07-29-2008, 06:30 PM
