Blowing Lighter Fuse
    Results 1 to 9 of 9
      Does anyone had experience with blowing fuse for lighters?
      I’ve already changed one and now again blowed. Already measured circuit and all looks fine. I’m using new Anker charger which works fine in other car.
      Is anything else connected on this fuse?
      Please help bcs now I’m confused and afraid to change fuse again.
      Oct 2018
      Do you have multiple lighter plugs in car? If there is, are the on same circuit? If on different circuits, try swapping the lighter plugs... if problem moves, you know it’s the plug itself.
      Oct 2016
      Bellevue, WA USA
      Your charger is putting too many amps then it was designed for through that particular cigarette lighter circuit. Other car has a larger amp carrying ability in the lighter circuit. Either hook the charger directly to the battery, get a charger that pushes less amps, or (not recommended) put in a higher amp fuse. Try another lighter circuit as Vovo suggested too
      SwedeSpeed.com
      Oct 2018
      I may have jumped the gun a little bit ... I totally missed the part about the charger.. lol
      Anyways, assuming your XC60 is set up like mine. When I use a battery tender (Noco g3500) through a lighter I have to use the one in the cargo compartment. I forget why... but when I went to the forward lighter it wouldn’t work at all, however I don’t think I blew a fuse trying it.
    7. #5
      Oct 2016
      Bellevue, WA USA
      With CanBus systems doing anything out of the norm electrical is a crap shoot. Even those USB lighter plugs can screw things up if it`s a cheap one.
    8. #6
      I think somehow is possible that + touch - inside plug if charger is spinning inside, I mean if someone do it by hand.
    9. #7
      Junior Member Maddo's Avatar
      Dec 2014
      Anyways, assuming your XC60 is set up like mine. When I use a battery tender (Noco g3500) through a lighter I have to use the one in the cargo compartment. I forget why... but when I went to the forward lighter it wouldnt work at all, however I dont think I blew a fuse trying it.
      I think it is because the rear lighter socket 12v is always live, whereas the front one depends on ignition selection.
      MY15.5 XC60 D5 AWD Luxury. P*. Driver Support Package. Front Blind View. Savile Grey
      1983 240 DL Beige (The old family car which lasted 17yrs)
    10. #8
      Jan 2011
      The 12v outlet in the cargo compartment is on a separate circuit than those in the floor console.
      I think Maddo is correct that the cargo compartment is always hot while those in the floor console are not.
      2007 S40 T5
    11. #9
      Jan 2009
      Quote Originally Posted by VolvoColombia View Post
      Had the same issue with a particular charger, two blown fuses, bought ten fuses, then threw the charger away and replaced it with another and never had a blown fuse again. I mostly have front and rear lighter ports connected to chargers.
    12. Remove Advertisements
    Similar Threads
    1. Cigarette Lighter Fuse Blowing Every Few Days
      By geokilla in forum S70, V70 & V70XC (1998-2000)
      Last Post: 11-18-2012, 12:41 PM
    2. Replies: 6
      Last Post: 08-19-2009, 09:20 PM
    3. Anybody got the lighter 2 pc. Rotors or Lighter R caliper's
      By EngTech in forum S40 & V50 (2005-2012)
      Last Post: 02-05-2008, 09:10 PM
    4. cig lighter fuse location
      By volvos40t5 in forum S60 (2001-2010)
      Last Post: 10-29-2006, 09:41 PM
    5. anyone know which fuse number is for the cigarette lighter/s
      By glenspeed in forum XC90 (2003 - 2014)
      Last Post: 06-21-2006, 09:38 AM
