Sagging sun visor - how the heck do you remove it?
    Results 1 to 8 of 8
      Jan 2020
      Greetings from the other Swedish car community! Longtime SAABCentral moderator and poster here.
      My parents have a 2016 XC90 with a sagging driver's sun visor - it won't stay up and I had to put some painter's tape on it in the interim, otherwise it blocks driving view. I removed the trim clip and unbolted the two 7mm bolts but can't figure out how the wire for the vanity light unplugs. Anybody know how? Was just going to order a replacement sun visor and replace it for them.
      Thanks guys!
      Jan 2020
      Any ideas on this?
      Member
      Aug 2017
      Do you have it pulled out enough to access the connector? Then you just pull to disconnect.
      SwedeSpeed.com
      Jan 2020
      Quote Originally Posted by Tech View Post
      I unbolted it and pulled it out as much as I dared with tension on the wire but there was no connector to speak of.
    7. #5
      Member
      Aug 2017
      It's up there.
    8. #6
      Sep 2018
      Quote Originally Posted by swedespeed7 View Post
      youd be surprised how hard you can pull on those little wires to get access to the connector
    9. #7
      Jan 2020
      Quote Originally Posted by brich999 View Post
      OK thanks, will give it a harder pull.
    10. #8
      Jul 2016
      This is rare for a newer Volvo to have this issue.
      On older Volvo's I advise customers to get this type of clip.
      https://www.staples.com/Staples-Bind...product_103549
      With visor in the up or normal position, Clip it on the visor side towards the windshield.
      Fold the lower metal tab back towards the sunroof.
      In the blocking the sun position do the opposite.
    11. Remove Advertisements
    Similar Threads
    1. Replies: 45
      Last Post: 02-06-2018, 07:01 PM
    2. sun visor for 760
      By volvoman9 in forum Want Ads
      Last Post: 04-25-2010, 09:22 PM
    3. How to remove the sun visor vanity mirror
      By denzo in forum S40 & V50 (2005-2012)
      Last Post: 04-29-2008, 10:04 PM
    4. Sun Roof, Dismounting Sun Visor
      By andreasschwerte in forum 850 (1993-1997)
      Last Post: 05-14-2004, 02:52 PM
    5. Anybody have the rear sun visor for the S60R?
      By Davideo in forum R Forum (2004-2007)
      Last Post: 02-08-2004, 11:49 AM
