Trunk water!
    Results 1 to 13 of 13
    Thread: Trunk water!
      Mar 2012
      Bothell, WA
      Trunk water!
      I suspected something was amiss when I found some damp papers at the bottom of the trunk a couple of months ago. Weather remained dry until recent snow and rain, when I found the trunk well was wet. Not so much on the upper surfaces. I hoped it was because there were loads of pine needles around the upper trunk edge, and that drainage was stopped up. Cleaned it all out, but after several days of rain, it’s even worse today. Soaked a lot up, but I suspect there’s more to this problem.
      Has anyone else had the same problem? How’d you fix it?
      THANKS!
      2013 C70 Platinum Plus. Polestar Tune. Mods4Cars Smart Top Module, Black Ember Metallic, Midir 18”. Bought 1/2018/13,800 mi.
      2004 XC70 (2008-2018 - 189,000mi.)SOLD
      May 2014
      Memphis, TN
      I got it too. Mine looks to be coming from the left drain, but haven't found a culprit yet.
      Sent from my 2PS64 using Tapatalk
      Current Volvos: 1996 850 Platinum Wagon (her name is Pearl/we're still in love, but my son inherited her after flipping his 2004 V70 2.5T) 2006 S40i (daughter named him Ronnie and promptly blew up the motor....gave him to my nephew and he put in another motor...Ronnie's 3rd motor!) 1998 V70 T5M ( her name is Daisy, we are still getting to know each other)
      Jun 2019
      This happened to ours when we first got it two years ago. I cleaned the rubber channels at the very rear bottom of the hardtop (there was sludge in there) and as I recall I also poked through the drain holes that are located there, and no problem since then, also not in heavy rains. I was prepared to replace the rear light gaskets and bought them, but so far have not had to install them.
      SwedeSpeed.com
      Apr 2005
      Montreal, Quebec, Canada
      Like the others said, check the drains along the trunk channel. When the drains back up, sometimes water seeps in through the seals for the rear taillights.
      I had the same issue, I replaced the two rear seals that go between the tailights and the body of the car.
      2019 V60 Cross Country T5 AWD - Premium pkg, Climate pkg, Vision pkg, Conv. pkg, Harmon Kardon, 20" wheels, Polestar tune
      2012 C70 T5 A - Polestar Tune, Elevate downpipe, VIVA Performance exhaust, JR filter, GoVo ECU spacer, 19"x8.5" Polestar Rep wheels, H&R spacers, Volvo OEM lip spoiler, Heico front spoiler lips
      2018 V60 Cross Country T5 AWD Premier - Premier Plus pkg, Climate pkg, Technology pkg, BLIS plg, 19" BOR wheels - sold
      2018 XC90 T6 AWD Inscription - Vision pkg, Climate pkg, Convenience pkg - Sold
      2017 V60 T6 AWD Drive-E - Premier pkg, Climate pkg, Tech pkg, Conv pkg, Sport suspension, 19" Portia wheels, Polestar Tune - Sold
      2005 V50 T5 M AWD - Passion Red/Graphite T-tec, sport pkg, Volvo body kit - Sold
      1998 S70 T5 M - Black/Graphite, 239whp/317wtq on old setup, List of mods RIP
      Your Canadian source for Original Volvo Parts and Accessories! - Parts.VolvoPointeClaire.com
    7. #5
      Junior Member nuge's Avatar
      May 2015
      DTLA
      Great info.
      Sent from my SM-N950U using Tapatalk
      2018 Volvo V60 Polestar
      2015 Audi Allroad
    8. #6
      May 2014
      Memphis, TN
      Quote Originally Posted by rj240 View Post
      So I ordered the tail light seals today. I've not looked back there to see how much work is involved. Can you give me a quick rundown on what needs to be removed to get those tail lights off?
    9. #7
      Apr 2005
      Here you go!
      Attached Files Attached Files
    10. #8
      I am wondering if anyone knows if the front grille to the 2020 XC90 will fit on the 2017 XC90. I figured that since it is cracked and needs to be replaced why not update the look as well.
    11. #9
      May 2014
      Memphis, TN
      I downloaded the PDF on to my phone but can't get it to open.
    12. #10
      Apr 2005
      Hmm...weird. Doesn't open for me either.
      Let me try to upload it again...
    13. #11
      Apr 2005
      Quote Originally Posted by rrochell8 View Post
      Strange, I have the same issue on my phone, but when I download the pdf on my PC, it opens just fine...
      I'll just post the pictures then...
    14. #12
      Apr 2005
    15. #13
      May 2014
      Memphis, TN
      Sweet action! Thanks my brethren! Saw that panel, but figured it couldn't be that easy.
    16. Remove Advertisements
    Similar Threads
    1. XC90 paint sensitive to water spots? (hard water)
      By stick_shift in forum XC90 (SPA: 2016 - )
      Last Post: 03-24-2018, 05:46 AM
    2. Water, flood, standing water
      By wcrowder in forum General FWD & AWD
      Last Post: 08-09-2013, 09:26 PM
    3. should one mix coolant with tap water or distilled water.....
      By 1sciroccofahrer in forum 850 (1993-1997)
      Last Post: 02-02-2007, 10:34 PM
    4. Installing additional Water Pump (intercooler water spray)
      By blot in forum R Forum (2004-2007)
      Last Post: 06-21-2004, 04:22 AM
