S70 front bearing-like noise
    Results 1 to 5 of 5
      Jan 2020
      Statesville, NC
      Hi all,
      My 2000 S70 has noises coming from front that have me stumped and I am hoping that someone can help with what to check next. When going down the road I am hearing what sounds like a bad wheel bearing noise even after replacing both front wheel bearings and rotating front tires to rear. Still the noise persists. It correlates with road speed and is invariant to having the car in gear or in neutral so am thinking its not a CV shaft although it sounds like it could come from one otherwise although I have replaced those recently.
      I've also spun the rear wheels to make sure that the noises were not coming from the rear bearings and also I checked the strut mounts too as I have heard those mentioned as possible culprits.
      What would be the next thing(s) to check ? I've heard something about a transmission bearing which may make sense as I don't think the noise is more on one side or the other. But I'm not seeing anything more than a mention so if that is the next thing maybe more on what to check if that is what I need to check next.
      ANY help would be much appreciated!
      Thanks all,
      Martin
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      pass axle carrier bearing
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      Jan 2020
      Statesville, NC
      Quote Originally Posted by ScottishBrick View Post
      So should I just replace the passenger side shaft ? I may or may not have replaced that in the past. Thanks!
      SwedeSpeed.com
      Dec 2014
      Connecticut
      Quote Originally Posted by [email protected] View Post
      Pull it and give the bearing a spin. If it feels smooth and is quiet, thats not it. If it doesnt spin super free and or growls.....thats the culprit.
      Just FYI the NA cars are 5 speed auto and use a different axle design than 4 speed auto/manual. Not sure what you have just leaving that information for either scenario.
    7. #5
      Jan 2020
      Statesville, NC
      That got it and it seems that the offending half shaft was the original one with 197k miles on it.
      Many thanks!
    8. Remove Advertisements
    Similar Threads
    1. engine surging bad ticking noise like valve or or rod bearing but it's not help
      By Paul8429 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 05-24-2016, 07:22 PM
    2. Replies: 7
      Last Post: 12-28-2015, 10:17 PM
    3. OEM Front Wheel Bearing & FCP Groton Rear Wheel Bearing Brand NEW
      By mehran05 in forum FWD & AWD Parts For Sale
      Last Post: 10-23-2012, 01:16 AM
    4. Replies: 9
      Last Post: 01-20-2011, 06:38 AM
    5. Replies: 12
      Last Post: 02-05-2009, 05:44 PM
