Side view mirror upgrade for pre-FL
    Results 1 to 4 of 4
      Aug 2016
      San Diego, CA
      Quote Originally Posted by torro View Post
      Bumping this old thread. Does anyone have the pinout for the different wiring?
      The new wiring vs the old (The two white cables at pin 1 & 2 are missing from the old contact)
      The only "color differences" are pink on the new vs brown/white on the old. Diagrams at Matthews Volvo might have the answer..
      Edit: After a bit of research I have come to this conclusion for the mirrors w/o memory:
      Edit 2: Re-pinned the contact today, and everything seems to be working alright.
      NEW:..................................................OLD:
      TEMP:
      Pin 1: White/black...............................Pin 1: White
      Pin 2: White.......................................Pin 2: White
      POWER:
      Pin 7: Gray —> Ground........................Pin 7: Brown/White —> Ground
      Pin 8: Pink —> My...............................Pin 4: Green —> My
      Pin 9: Green —> Mx.............................Pin 3: Gray —> Mx
      HEATER:
      Pin 12: Black —> Ground......................Pin 12: Black —> Ground
      Pin 11: Black/Gray...............................Pin 14: Black/Gray (possible different colors)
      INDICATOR:
      Pin 14: Black/Blue................................Pin 6: Black/Blue
      PUDDLE:
      Pin 14: Black/Blue................................Pin 13: Black/Red (notice: Shared cable on the newer mirror)
      Has anyone tried this recently?
      Is the quote above saying that in the new side view mirror, I need to:
      Take pin 8 and put it in pin 4
      Take pin 9 and put it in pin 3
      Take pin 14 and put it in either pin 6 or 13?
      Take pin 11 and put it in pin 14
      All advice welcome.
      2005 Volvo V50 T5 AWD M66 (2017 - ) || 1987 Toyota MR2 (2016 - ) || 2002 Lexus IS300 (2016 - ) || 2005 Volvo S40 T5 AWD M66 (2016 - 2019) || 2008 Volvo V50 T5 (2015 - 2016) || 2001 Acura Integra GSR (2010 - 2010) Stolen lol
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      Thanks for digging up this info. I'm planning to do the transplant also and have been digging through the wiring diagrams. I also took photos of my 2005 mirror connectors and have as set of 2007 (larger) mirrors. I am wondering if the harness changes from 2007, which is pr-FL but had larger mirrors, to the Post-FL 2008+.
      I'll let you know what I come up with.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
      Aug 2016
      San Diego, CA
      Quote Originally Posted by AutoGeek View Post
      I have a set of broken 2007 mirrors that I'm experimenting on, a single 2009 mirror, and another set of 2007 mirrors that I actually plan on using.
      I should compare them all.
    5. #4
    6. Remove Advertisements
    Similar Threads
    1. Windows/mirrors steering switch - is FL compatible with pre- FL ?
      By LizardOfBodom in forum S40 & V50 (2005-2012)
      Last Post: 07-19-2017, 04:42 AM
    2. Replies: 0
      Last Post: 02-20-2012, 04:04 PM
    3. Replies: 3
      Last Post: 10-05-2006, 12:01 PM
    4. Spotted: Black S60R in Davie, FL. (South FL.) Area
      By JHEIII850Turbo in forum R Forum (2004-2007)
      Last Post: 06-30-2006, 07:16 AM
    5. Replies: 5
      Last Post: 03-01-2005, 11:17 AM
