Timing Belt Slack
    Results 1 to 13 of 13
      Jul 2014
      Timing Belt Slack
      Hi, you all helped me work through some wierd issue in a recent thread, but it continues...
      The timing belt has too much slack...
      I rotate the engine clockwise with a ratchet, and it seems okay, gripping all the sprockets, tension seems sufficient, I can feel the resistance of the cams pushing the valves open.
      If I stop rotating, the belt springs back and the section from the intake cam down to the crankshaft appears loose, wayy too loose.
      If I rotate it backwards, the belt wants to slip over the intake cam.
      The tensioner bearing is not being fully pushed up by the tensioner it seems, or the belt is too long, I can move the tensioner arm up and down loosely about 1mm.
      I replaced the belt with the correct part number for early model with hydraulic tensioner, and I have replaced the tensioner now as well.
      Water pump is new as of a couple months ago, I remember the original water pump had a different looking sprocket, it had "blank spots" equally spread out on some of the teeth, the new one has teeth all the way around. It's not possible that the water pump had a smaller sprocket is it? This one pump fits 850, 960, C30, C70, S40, S60, S70, S80, V40, V50, & more according to FCP so it seems like there isn't even variation in the water pump onwards of 2000.
      I'm at such a loss here, plz any help or advice is greatly appreciated.
      Jan 2020
      Quote Originally Posted by spiffy926 View Post
      Hi spiffy,
      Can you post a picture of the timing system?
      Jul 2014
      SwedeSpeed.com
      Jan 2020
      I do not see an idler pulley in your setup. Please verify that you have your idler pulley installed in your timing system. It should sit up and to the right of your tensioner.
      https://www.fcpeuro.com/products/vol...ller-9146376-1
      ERA
    7. #5
    8. #6
      Jul 2014
      Thanks guys I guess that would explain a lot...
    9. #7
      May 2018
      Takoma Park, MD
      You're gonna have to pull the tensioner again and push the pin back in SLOWLY.
    10. #8
      Jan 2020
      Quote Originally Posted by hatchbackkid82 View Post
      Yes, can be done easily with a C-clamp.
    11. #9
      Jul 2014
      ^^ Got that part down, trying to set the timing without the idler installed must have been part of the reason it was so hard to get set in time, meaning that I already re-set the tensioner half a dozen times; which was part of the reason why I assumed it had failed, but it turns out (after already getting a replacement) that the tensioner wasn't the issue. So... time to dig the idler out of the scrap bin and get it back installed and happy... 3 month delayed project about to wrap up?? Fingers crossed.
    12. #10
      Jan 2020
      [QUOTE=spiffy926;7506401]^^ Got that part down, trying to set the timing without the idler installed must have been part of the reason it was so hard to get set in time, meaning that I already re-set the tensioner half a dozen times; which was part of the reason why I assumed it had failed, but it turns out (after already getting a replacement) that the tensioner wasn't the issue. So... time to dig the idler out of the scrap bin and get it back installed and happy... 3 month delayed project about to w
      Got my fingers crossed for you!
    13. #11
      Jul 2014
      Wow she's back n running I almost couldn't believe it myself, thanks for the help!
    14. #12
      Jan 2020
      You bet, any time! Glad you got the ol' beast running.
      ERA
    15. #13
      May 2018
      Takoma Park, MD
      Awesome sauce! Look as someone that gets frustrated extremely easily, sometimes taking a break or taking a step back helps. Glad you didn't lose your patience and got it back up and runn
    16. Remove Advertisements
    Similar Threads
    1. Replies: 1
      Last Post: 03-22-2019, 11:04 PM
    2. Rear seat belt stuck and wont extend out, but has plenty of slack
      By jhleung in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 09-14-2016, 01:28 AM
    3. Question: Does axle ping = lots more drivetrain slack?
      By Warpedcow in forum R Forum (2004-2007)
      Last Post: 08-12-2009, 04:41 PM
    4. Drivetrain slack in T5M
      By T5 for Life in forum S70, V70 & V70XC (1998-2000)
      Last Post: 05-01-2006, 12:53 PM
    5. Is there some slack in the 4wd?
      By maxspeed30 in forum R Forum (2004-2007)
      Last Post: 05-04-2005, 01:06 AM
