Poor door handle lock/unlock response?
    Results 1 to 6 of 6
      Aug 2018
      Been having increasing difficulty with getting the door to lock/unlock using the door handle. Don't know if it has to do with the weather (live in NY), but I need to try multiple times, with multiple hands with multiple handles to get the car to lock/unlock. I used to get a better response when using the rear door handle than the driver door, but even that door is pretty unresponsive now. I also exclusively use the sports/activity key fob, not the regular key fob. It's always in my pocket, usually without any other phones/cards or possibly interfering devices. Anyone else have this problem? Found a fix?
      Sep 2019
      So Cal, USA
      If you use the normal FOB for a day-or-two, do you have the same problem?
      My thought being, as batteries get weaker (in your sports FOB), their ability to communicate with your car becomes more irratic before they finally give out. I just replaced the FOB battery in my Mom's Honda not two weeks ago with similar symptoms to what you report, and it resolved all her concern. Good luck!
      Bert
      Present: ‘20 XC60 T8 Inscription
      Past: ‘15 Tesla S90D; ‘14 SLK250; '13 RX450h; ‘09 335i; ‘06 RX400h; ‘02 SC430; ‘99 RX300; ‘95 SC300; ‘91 Legend...
      Member
      Jan 2003
      Music City
      Just to note that this may be a sign of diminished battery. The regular FOBs have a CR2032 battery that is easy to replace but the sport key does not contain a replaceable battery. I read my owners manual re: this and you have to take it to a Volvo dealer to have it de-activated and you purchase a replacemnt key that they then assign to your car. The deactivation prevents the old sports key from opening your doors by someone else.
      The current: 2019 XC40 T5 AWD Inscription/Crystal White/Blonde - Adv, Conv, Vision, Heated Wheel & Front Seats, 19" wheels
      2018 XC60, OSD T5 AWD Inscription/Denim Blue/Blonde - Adv, Conv, Vision, Heated Wheel & F/R seats.
      The old: 2001 S60 - totaled, 2003 XC90, 2004 S80, 2005 TSX, 2006 S60, 2009 V70, 2010 S80 - totaled, 2012 C30 T5 OSD-sold but kept it in the family, 2012 XC60 Caspian Blue/Beige, 2015 Hyundai Genesis.
      SwedeSpeed.com
      Sep 2018
      tech bulletin says make sure phones are more than 4 inches from keys or they can interfere. that being said, its probably the sport key battery getting weak. dealer will warranty, and i would start carrying the main key because it has a back way into and to start the car if the battery in the key goes too low. though i guess with voc app, can get in that way(if you have cell service) and sport key should read in the center console spot
    7. #5
      Aug 2018
      I figured it might be the battery in the sports fob, it'd be such a hassle to go to the dealership to get it replaced, was hoping someone else might have had similar experiences and a diy solution lol
    8. #6
      Junior Member Funbobby's Avatar
      Nov 2009
      Winnipeg, Manitoba, Canada
      Phone in the same pocket as key's always causes me problems. I also have a small RFID blocking credit card holder, this too causes an issue when in the same pocket as key. Remove and everything works as expected.
    9. Remove Advertisements
    Similar Threads
    1. How to: fix driver's door key that turns but doesn't lock/unlock door
      By Avboden in forum S70, V70 & V70XC (1998-2000)
      Last Post: 05-17-2018, 05:55 PM
    2. auto unlock door handle not working
      By 04lss in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 10-21-2016, 01:20 AM
    3. Replies: 164
      Last Post: 03-15-2014, 11:14 AM
    4. Left rear door lock pin refuses to obey lock/unlock buttons
      By frontwheeldriven in forum S40 & V50 (2005-2012)
      Last Post: 12-13-2009, 05:21 PM
    5. Double take on the interior door handle to unlock and open door
      By barrysharp in forum V70 & XC70 (2008 - 2016)
      Last Post: 12-15-2007, 02:09 PM
