Moynis Volvo 965 Build Thread
So this is the $800 Volvo 960 I picked up back in September, I figured I would post my updates that I usually put on my website on here as well, maybe generate some more traffic to the 960 board here since they are pretty competent cars and the very last of the RWD Volvos.
The body is in pretty good condition, but its definitely a little rough around the edges. The car itself has over 190k on the clock, and all of its history up to this point is a mystery to me. Surprisingly I am only the 3rd owner of the car, and I intend, or at least hope to, get the car back into a running / driving condition.
While I was able to drive the car home, it definitely needs a lot of work before I would consider actually driving it anywhere. As it stands it needs (in no particular order):
Timing Belt and Serpentine Belt
Oil Change and Fluid Flush
Oil Cap Gasket
New Spark Plugs and Ignition Coil (Misfire on Cylinder 3)
New Idle Air Module
Headlight Bulbs
New Taillight Assembly and Bulbs
New Brakes
New Front Suspension
Fix Seat Rail Motors
Interior and Exterior Deep Clean Detail
There is likely other stuff, but these are the items I would consider to be the 'bare minimum' of what needs to be done to at least get it running and driving around. There is a good list of cosmetic items that I also have planned like fixing the missing trim and fuel door. Thankfully this car, and its parts, are dirt cheap and will allow me to experience the world of RWD Volvos. I'm hoping to do some videos and a lot of write ups on this car. Much like the P3s, there arent a ton of enthusiasts around the 900 series cars, much less the inline 6 versions.
Oil Cap Gasket
New Idle Air Module
Headlight Bulbs
New Brakes
