99 S70 Turbo Engine Swap Adventure
    Results 1 to 6 of 6
      Jan 2020
      Cool 99 S70 Turbo Engine Swap Adventure
      Hi Guys and Gals. I've got a 99 S70 Turbo AWD which I've taken the head off of and had it rebuilt and shaved with vvis on the exhaust and the rest I pulled from the car because of several cracks in the sleeves. I also have a 95 2.3L Turbo engine from a wagon that has good compression - all in the 190-195 psi range with 162,000 miles. I've already swapped the oil pans, intake and exhaust mans plus the turbo. My question is b-4 I start installing it, I thought I should get some of your expert advice. So, is this doable and thank you all for any advice you share.
      What exhaust manifold did you put on it?
      I dont see a reason that it wouldnt work. Need to keep all the ME7 parts on the head and accessories.
      You will need to use the front lower motor mount bracket from the 95, fuel system components from the 99.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      Jan 2020
      Thanks so much for your reply ScottishBrick. I've been struggling with the fact that these engines are really packed into these engine bays and my size doesn't help at 6 foot eleven with unusually gigantic hands. I keep telling myself patience and that helps, but I think your words of encouragement has sparked a new jolt of energy in me. thanks again, I will post up some pics after I hear it run out of limp mode, JJSS70.
      Jan 2020
      I'm sorry, ScottishBrick. I forgot to answer your ex. man. question. I have the 99 ex. and int. mans. in it with the 88 turbo which will stay. I just have to put it all back on the 99 cyl. head and then the brain will see the cvvt and hopefully end up in open loop. Still curious about TB tensioner though. I guess I'm going to find out. Thanks again, JJSS70.
      Quote Originally Posted by JJSS70 View Post
      Gonna need to use the N style earlier tensioner
      Jan 2020
      Thanks a lot and will post pics. JJSS70
    9. Remove Advertisements
    1. Engine harnesses from '95 850 Turbo & '99 S70 AWD, 960 coil packs, etc.
      By badcadman in forum FWD & AWD Parts For Sale
      Last Post: 01-30-2020, 05:59 AM
    2. volvo 850 engine swap with a s70 engine.
      By russkie1994 in forum 850 (1993-1997)
      Last Post: 08-01-2015, 11:54 PM
    3. Rookie in need of help.. engine swap S70 2.4 to 2.5 turbo
      By KevinSchuit in forum General Volvo Discussions
      Last Post: 08-24-2014, 08:38 AM
    4. Sport Trans. mode on 99 & 00 S70 T5's? There in 98 but gone in 99 & 00?
      By kcc455 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 09-16-2003, 02:54 AM
    5. Engine bay painted (first ever auto painting adventure)
      By doug242ti in forum 240, 242, 244 & 245 (1974-1993)
      Last Post: 06-06-2003, 09:03 PM
