Need advice on weird driving
    Results 1 to 10 of 10
      Sep 2019
      Hey guys, my car is a 2012 S60 T6 R-Design. When driving, mostly at higher speeds, the car randomly “sways” back and forth while driving completely straight, doesn’t seem to happen on curves. Been told by my mechanic that the entire suspension looks great and I recently had an alignment done and new tires less than 6 months ago. Anyone had this issue or might know what it could be?
      May 2015
      It's raining - must be near Seattle
      Crosswind?
      I'm not good, I'm not nice, I'm just right.
      2012 S60 T6 R-Design | 1998 S70 T5 SE | 1986 944 Turbo
      Junior Member chrisz's Avatar
      Nov 2015
      Cambridge Ontario
      Did the weird driving sensation start with the installation of new tires? I've had something similar when I put on winter tires on the front with all season tires on the back of the vehicle.
      SwedeSpeed.com
      Member
      May 2003
      Does you car have the lane-keeping assit option? My car does, and I often feel it nudging the car away from lane markings (or at least what it thinks are lane markings).
      Toe-out will have that symptom
      Rutted roads, and as mentione crosswinds will do it
    7. #5
      Member
      Aug 2011
      RI
      I’ve had this happen when driving on the highway behind large vehicles, even without being close behind them
      2002 S60 T5M
      235K miles
      Black Sapphire Metallic
    8. #6
      Nov 2018
      I would expect some feedback in the steering wheel when the car sways left and right. What are you feeling with your hands?
    9. #7
      Sep 2019
      No crosswinds from what I can tell. Alignment should be fine as I avoid holes and hitting the curb and such, but I will probably get it checked again. It wasn’t directly after new tires, it only started a month or so ago and new tires were several. And absolutely no feedback from the car, it sways and I don’t feel anything in the steering wheel
    10. #8
      Nov 2018
      If your car has "Four C" active suspension, it could be that the electronic system is hunting for a level body platform in some conditions, as the road surface undulates. My 2005 S60 has passive suspension, with no shock absorbers being connected to any of the many electronic modules on board. I believe that the active suspension system has several modes that can be selected by the driver. You might try a selecting a different mode.
    11. #9
      Oct 2013
      San Francisco Bay Area, Calif.
      Do you notice the problem on certain stretches of road?
      Some sections of freeways have parallel grooves running along them for better wet weather safety.
      In cars with certain tires there can be some "tramlining" on such roads which slightly steers the car the car one way or the other. Worse with directional tires. It's not specific to Volvos.
      See this TireRack article about it.
      2012 S60 T5
    12. #10
      Sep 2019
      Interesting, have Sumitomo htr a/s po2 tires and it says they are directional so that might be it, I will need to pay more attention to the road while it happens. Don’t have 4C as it’s an R-Design, but I will try the different driving preferences
    13. Remove Advertisements
    Similar Threads
    1. Really weird sound while driving (video)
      By Dfunk in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 03-01-2016, 08:21 PM
    2. Sand Driving For 2011 Xc90, Need advice
      By hatam04 in forum XC90 (2003 - 2014)
      Last Post: 03-13-2014, 06:33 AM
    3. R Won't Start Unless in Neutral - WEIRD WEIRD WEIRD
      By 23109VC in forum R Forum (2004-2007)
      Last Post: 10-03-2006, 02:56 PM
    4. Replies: 15
      Last Post: 01-24-2005, 10:45 AM
    5. Weird, Really Weird
      By paxcam in forum XC90 (2003 - 2014)
      Last Post: 05-07-2004, 10:07 PM
