1999 transmission compatibility
    Results 1 to 4 of 4
      May 2018
      Corvallis Oregon
      I'm replacing the trans in my 1999 v70R, found a local guy who has a 1998 v70 awd trans. Is this comparable, not sure since its different engine managment.
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Not compatible.
      You need a 99 awd trans from: 99 awd, 99 R or 99 xc. cannot use 00 or 98.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      May 2018
      Corvallis Oregon
      Ok thanks, seem like it might be a real pain to find a trans.
    5. #4
      Dec 2014
      Connecticut
      Quote Originally Posted by Parker View Post
      Hardly. You're looking for one of the most prolific transmissions.
      Car-part.com
      Just looked in your area and found 50+ listed, anywhere form $200-600
    6. Remove Advertisements
    Similar Threads
    1. P80 AWD Compatibility between 1998 and 1999 models
      By volvolars84 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 03-17-2018, 03:05 AM
    2. New Member Intro / 01 XC70 Transmission Swap Compatibility
      By reintjes in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 02-26-2013, 11:18 PM
    3. Transmission flush time...fluid compatibility question?
      By AlexL in forum R Forum (2004-2007)
      Last Post: 02-07-2013, 01:03 PM
    4. GT Transmission compatibility from 04-07 R?
      By burg_855t in forum R Forum (2004-2007)
      Last Post: 09-16-2012, 12:25 PM
    5. transmission compatibility
      By jmmartin155 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 10-12-2010, 11:10 PM
