2019 S60 B&W Door Speaker Trim Removal
    Results 1 to 6 of 6
      Aug 2017
      Phila, Pa.
      Question 2019 S60 B&W Door Speaker Trim Removal
      Hello,
      I am looking to replace the "plastic" speaker trim in the front passenger side door (picture attached).
      Can someone either link or explain the best way to take it out in order to put a new one in? Do I have to remove the whole door panel? Or does the trim pop out?
      I don't want to break any clips but also don't want to remove the door panel if I don't need to.
      This is the part I am looking to replace -> https://www.volvooempartsdirect.com/...lding-31490193
      Thank you...
      Jan 2019
      Concord, MA
      Quote Originally Posted by 01byte View Post
      Hello,
      Thank you...
      If it's anything like the V/S90, the grill is plasti-riveted to the doorcard.
      Aug 2017
      Phila, Pa.
      So if I needed to remove that plastic trim piece (the one that holds the grill). Can I do it without having to remove the whole door panel?
      SwedeSpeed.com
      May 2019
      Wayland, MA
      Yes the plastic trim piece pops out, ideally you have a plastic trim tool you can gently insert and pry around the perimeter there are clips all around start at the front and pry your way around.
    7. #5
      Aug 2017
      Phila, Pa.
      Quote Originally Posted by Power6 View Post
      Perfect!!! I do have a set of trim removal tools. I just didn't want to start trying to pry and break some clips that would force me to replace the whole panel (which is expensive).
    8. #6
      Member
      Aug 2017
      United States
      That piece just pries off. It needs to be removed to remove the door panel because there is a screw behind it holding the door panel on. Start at the edge closest to the front of the car. There is a plastic piece toward the back that slides into the door panel.
    9. Remove Advertisements
    Similar Threads
    1. Replies: 0
      Last Post: 01-10-2018, 02:37 PM
    2. My noise(s) #*$&*()&#$(*&($*%&(*$(&% My rant of the day!
      By JRL in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 04-24-2016, 09:26 AM
    3. Replies: 12
      Last Post: 03-31-2016, 09:17 AM
    4. "Drift Assist"?
      By Fmfosnacht in forum XC90 (SPA: 2016 - )
      Last Post: 12-02-2015, 01:47 PM
    5. Replies: 3
      Last Post: 08-29-2014, 09:09 AM
