Charles
    Results 1 to 11 of 11
    Thread: Charles
      Charles
      I just bought a 2006 v70 2.5T, and I was made to understand that the transmission filter is not accessible, so I am thinking to install an in line Magnefine magnetic oil filter. Question, has anyone done this installation, and is this a good or bad idea? Thanks Chas.
      Apr 2013
      Toronto, Canada
      Yep, I’ve installed one. Easy stuff. Can’t hurt.
      2010 V70 3.2 125,000miles
      2002 V70XC, 175,000 miles
      2004 S60 2.5T, 160,000 miles
      Sep 2017
      Colorado
      Quote Originally Posted by [email protected] View Post
      Yea, a 3/8" one on the return line from the transmission is a common addition around here.
      2001 V70 Silver - 198k miles
      2006 XC70 Ocean Race - 95K miles
      (Past: '94 944 turbo, sold at ~220k miles)
      SwedeSpeed.com
      Question, I am assuming that the oil flow is from the top of the radiator (Green plastic lock) to the top of the transmission (drivers side), and where did you tuck the filter? Thanks for all your help, Chas.
    7. #5
      Sep 2017
      Colorado
      Yes, you have the flow direction correct. I misspoke abut the return line when I meant to say the feed line is where people put the filter. Pics below of this on my V70 NA. If you can loosen the fitting on the transmission you can swivel things and make it fit nicely, otherwise you have to remove length from the line so it doesn't kink when installed, thus starving the transmission.
    8. #6
      Thanks a lot for these pictures, great help. Question, how often (miles) do you replace this filter? I will get this installed and post the results; thanks a bunch Chas.
    9. #7
      Sep 2017
      Colorado
      I only have ~10kmi on mine thus far. My recollection is that folks tend to replace them when they change the transmission fluid, so 30-60kmi depending on who you ask.
    10. #8
      Thanks a bunch, really appreciate your help, Chas.
    11. #9
      Member Antherzoll's Avatar
      Dec 2013
      Toronto
      https://forums.swedespeed.com/showthread.php?p=5322209
      I do mine every 30k mi along with a fluid change. They work and I highly recommend installing one.
      2005 XC70 Crystal Green | Hilton | 16T | Bad Swede | 145k mi
    12. #10
      Thanks a bunch for all your help, Chas.
    13. #11
      Would like to thank you all for all the information you supplied in installing this transmission filter! Completed the job today, coupled with the installation of a tranny oil cooler with two small fans, and a 130 degree F thermal switch attached to the radiator top hose. The installation went well, because with the cooler installation I had more hose and space to get the filter in. Thanks again for all your help, Chas.
    14. Remove Advertisements
    Similar Threads
    1. Charles Phillips
      By [email protected] in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 07-13-2019, 11:49 AM
    2. Mr Charles U
      By [email protected] in forum New Member Forum
      Last Post: 01-11-2019, 12:52 PM
    3. New Indy repair shop in St. Charles MO
      By swedewrench in forum New Member Forum
      Last Post: 11-05-2013, 10:17 AM
    4. IMs sent to Rob & Charles
      By RearWheelPaul in forum Capital Chapter (Canada)
      Last Post: 09-03-2007, 01:06 PM
