NA Cam upgrade timing marks
    Results 1 to 2 of 2
      May 2018
      Takoma Park, MD
      Wrapping up the NA cams upgrade on my S70. I’m a little nervous about starting her up. When i had the timing marks spot on, right in the middle there was no way i could get the timing belt on. It seems to have been off by about half a tooth on each side.
      Now I’ve adjusted the cams gear slightly and the belt was able to go on easily. The crank mark is right in the middle but the timing marks on the cam gears seems to be off a little. I am able to rotate the crank with minimal resistance. I never hit a spot where the crank feels stuck.
      Do you guys think I’m good? I can’t remember when i did the timing belt the first timing of the marks were right in the middle or not.
      The head is from another 98 turbo model, and was milled,not sure of it matters.
      Attached Images Attached Images
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      The NA intake cam has 7 degrees more duration and starts opening 4 degrees sooner. The NA exhaust cam has 3 degrees more duration and starts opening 2 degrees later. So to replicate the base turbo cam settings on NA cams you should retard the intake by 4 degrees and advance the exhaust by 5 degrees.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
    4. Remove Advertisements
    Similar Threads
    1. Replies: 6
      Last Post: 10-21-2016, 10:49 PM
    2. confused on cam marks and CEL
      By mercdoc in forum S60 (2001-2010)
      Last Post: 01-26-2016, 01:58 PM
    3. What if timing marks on cam gears don't line up???
      By daniel2296 in forum R Forum (2004-2007)
      Last Post: 04-22-2014, 11:39 AM
