Headlight upgrade
    Results 1 to 6 of 6
      Jan 2019
      Headlight upgrade
      I recently picked up a 99 V70 to add to my collection and have noticed the headlights are less than great. After some initial research, it seems the e-codes are nearly impossible to find, especially the "jewel" variant.
      I believe these are the e-code jewels that are highly sought after:
      I'm a little hesitant about knock-offs, but I'd be open to these if they performed well. I just don't want them to turn yellow-hazy in one season.
      Has anybody tried these? https://www.carparts.com/details/Vol...020001-HD.html
      I'd love to see what they look like on the car.
      These just don't do it for me (not to mention the nearly $500 price tag): https://www.ipdusa.com/products/6956...rmarket-350006
      Any advice would be greatly appreciated, thanks!
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Linked VNL lights arent for P80s. The ABM projectors ipd sells can be had for significantly less but without extensive modifications, suck.
      Can get E codes that arent "jewel" type, or can get USDM jewels.
      I actually have genuine e code glass for sale at the moment.
      Post up a pic of your lights so we can see what youre working with to start.
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 293k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      Junior Member kampman's Avatar
      Jan 2013
      Columbus, Ohio
      I think the first set of lights you linked are for a semi, I wouldn't count on them fitting your car.
      If you want jewels, DEPO makes an affordable reproduction - you can find -them on eBay. I have a set on my V70R and the light output is terrific compared to the original lights. They aren't technically e-codes but they're pretty close pattern wise. They aren't packed the best from the factory and sometimes they have QC issues but they're pretty good for what they cost.
      1966 220/dormant project
      1984 245 Turbo/105K
      2006 V50 T5M AWD/151K
      SwedeSpeed.com
      Dec 2014
      Connecticut
      Well....e codes and DOT jewels are pretty much exact opposites:
      Jewels
      E codes
      Then thereís ecode projectors which result from tuning up the ABMs
      Canít find the night shot of them at the moment
      Edit: Found it on SS
    7. #5
      Jan 2019
      Wow thanks so much for the detailed responses. I did a buff/polish on the lenses and they're a little better but still not great.
      Thanks kampman, I'll consider putting those on my wishlist for after the suspension work.
      ScottishBrick -- here's what I'm working with right now:
    8. #6
      Dec 2014
      Connecticut
      Theyíre not great cause the reflectors are toast. Usually the problem.
    9. Remove Advertisements
    Similar Threads
    1. to upgrade or not to upgrade?
      By TG in forum S40 & V50 (2005-2012)
      Last Post: 04-23-2010, 03:31 PM
    2. To Upgrade or Not to upgrade?
      By AutoFahren in forum S40 & V50 (2005-2012)
      Last Post: 09-12-2009, 12:30 AM
    3. Why can you upgrade performance with an ECU upgrade?
      By gatorbrit in forum S60 (2001-2010)
      Last Post: 06-03-2009, 02:25 PM
    4. question about s60r engine upgrade upgrade !!!
      By frenchs60r in forum R Forum (2004-2007)
      Last Post: 04-01-2009, 04:33 PM
    5. To Upgrade or Not to Upgrade...
      By D-Autobahn Guy in forum R Forum (2004-2007)
      Last Post: 06-04-2005, 11:44 PM
