Unlike Rick Moranis, I do not want a spaceball in my Volvo
    Results 1 to 17 of 17
      Jan 2013
      Champaign, IL
      So I don't know what the deal is with car makers and the movie Spaceballs.... First Volvo and the spaceball then Tesla and ludicrous speed.
      I have a spaceball shifter and I don't like it. I'd like to trade someone for a standard shifter. I'll post a picture of the connections on the spaceball. If you've got the same connections on a standard shifter and are willing to trade let me know.
      May the schwartz be with you!
      Dec 2016
      Hamilton
      Quote Originally Posted by Dentedhoodv70 View Post
      This is the best advert here yet. Thank you sir.
      P.S. Mine’s auto. Good luck.
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      What trim do you want? Auto and non spaceball use the same plate. Just need the boot to match and you should be good to go
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 295k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      SwedeSpeed.com
      Dec 2016
      Hamilton
      I do have a spare used pleather boot (OEM) and shift knob from an 04 XC 70. Just remember. I may even have a silver trim, non XC. Lemme know.
    7. #5
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      Space balls! Oh sh**, there goes the planet
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
    8. #6
      Jan 2013
      Champaign, IL
      According to what I read, the shift knob is different as well. The spaceball knobs you push down and twist counterclockwise. I believe the standard knobs you pull down on tabs under the boot. It's going in a 2001 v70, but I liked the feel of the 2004 shifting. The 2004 has different cables and a counterweight on the transmission lever. I believe I need a shifter out of a NA car.
    9. #7
      Dec 2014
      Connecticut
      Or T5. Bunch floating around on eBay cheap.
    10. #8
      Dec 2014
      Connecticut
    11. #9
      Junior Member b5v6's Avatar
      Sep 2004
      San Diego, CA
      Here's a 6 speed C30 knob I took to an upholsterer to have a boot added to the shifter plate deleting my Spaceball. The C30 knob installs the same way (pushdown and twist).
      Sent from my motorola one zoom using Tapatalk
      '05 S60R - 2.4R, RaceS60R FMIC, RaceS60R Downpipe, SPEC LWFW/Stage 3 clutch, Elevate upper mount, Forge CBV, Phuzzy HDTCV, Eibach, IPD Sways, Powerflex/Superflex CA bushings, JVC M730 Head Unit (Android Auto, Subwoofer, Back Up Camera)
      '99 Audi A4 1.8T Stage 3...
    12. #10
      Dec 2014
      Connecticut
      Quote Originally Posted by b5v6 View Post
      Without the spaceball surround that would really do it for me. Nicely done on that retrofit!
    13. #11
      Sep 2004
      San Diego, CA
      Quote Originally Posted by ScottishBrick View Post
      All you need is the C30 6 speed shift knob, no other parts. Remove the shifter trim, then Spaceball (just unclips), aand take the knob and shifter plate to an upholsterer.
    14. #12
      Jan 2013
      Champaign, IL
      So I Should clarify here. The donor car is an '04 S60 5speed w/spaceball. My car is an '01 V70 T5 stickshift. I can't use the '01 shifter because the cables are different on the '04. I want the '04 transmission and cables because the shift feel is better. The plan is to put a stock s40 woodgrain knob on a shifter compatible with the spaceball shifting cables. Lloyd Dobber put the s40 knob on his '01 v70 T5 shifter and that knob is the same for s40 stick shifts from '00 to '08 or so. The spaceball knob mounts differently than the '01 V70, so I know they are not compatible.
      So I thought I'd throw it up here first to see if anyone wanted to trade or maybe someone has a shifter they want to sell. If not, I'm doing a junkyard tour of the NorthEast this summer and I'll pick one up cheap.
    15. #13
      Member LloydDobler's Avatar
      Aug 2007
      Littleton, CO
      Not that it matters but you're mis-remembering, I used a S60/V70 wood knob. It was the straight key with retaining clip under the boot design. P/N 8671187.
      2003 C70 T5M Convertible - Eibachs, Koni FSDs, Enkei RSF5s, OBX downpipe, Snabb intake, RIP kit, & drop-in intercooler, Quaife LSD, 19T, Green Giants, 22 psi Hilton tune.
      2006 V70 2.5T - Ice White - Oak Arena, (almost) bone stock daily driver.
      1966 122s - Collectible project, restoration and many mods on the way.
      2005 V50 T5 AWD - Daughter's first car. No mods unless she does 'em herself.
    16. #14
      Dec 2014
      Connecticut
      The “stock” non spaceball shifter is pretty nice but the boot ends up being kinda expensive from volvo:
      Shifter plate is the same as auto cars. Boots are -04 or 05+ specific but they are cross conpatible it’s just that the -04 in the 05+ sits a quarter inch low.
      I’m running the sport knob to match the sport wheel and a basic boot. There is a leather “sport” boot but it’s not amazing enough to warrant buying imho
    17. #15
      Oct 2010
      Over the winter break I swapped my 2001 cables and shifter for 2004, and can confirm that the Turbo and NA cars have exactly the same shifter. It was more painful than expected (see my bracket posts), but well worth the upgrade IMHO, specially with SNABB shifter to tunnel bushings.
    18. #16
      Jan 2013
      Champaign, IL
      Thanks Chris - I had the P/N right but I thought in the thread it was a from an s40. No wonder I couldn't find one - I've been searching the junkyards. And they raised the price of those things, they are $157 at Tascsa now.
      Mr. Brick - Is that your '03 V70? Looks good. What is the light button on the center console?
      Zak - I'll check out your posts. And it was a pain just getting the stinking cables out of the donor car!
    19. #17
      Dec 2014
      Connecticut
      That’s my 03 T5M. Button is for the aux driving lights.
    20. Remove Advertisements
    Similar Threads
    1. Rick Perry's strange New Hampshire speech
      By adp in forum Off Topic Forum
      Last Post: 11-27-2011, 12:01 PM
    2. Rick Wagoner resigns
      By JRL in forum Car Lounge
      Last Post: 04-01-2009, 10:19 AM
    3. I am not going to Rick Roll Swedespeed ever again
      By Copeland in forum Off Topic Forum
      Last Post: 09-20-2008, 01:31 AM
    4. Replies: 3
      Last Post: 09-16-2008, 06:07 PM
    5. Rick Steves "discovers" Chimay and likes it
      By BarentsBlueV50 in forum Off Topic Forum
      Last Post: 08-22-2008, 07:22 PM
