Growling Sound on Acceleration
    Results 1 to 11 of 11
      Junior Member voldog's Avatar
      Oct 2017
      Grand Rapids, Michigan
      Was driving my Sister's 2010 XC90 with 110k miles the other day. It drives fine but noticed that that when cruising along between 30mph to 60mph and I press the gas to accelerate there is a growling sound coming from the front. Can't tell whether its from engine or drive train. According to them its been that way since they got the car at around 30k miles. The dealer supposedly told them thats the characteristic of the 3.2. Any thoughts.
      IF IT AIN'T BROKE - DON'T FIX IT!
      04 Volvo XC70 5LT 120k Ruby Red - Nice hiway ride, stiff and bouncy in city, problematic door locks and tendency to lock you out, deteriorating moulding trims, groaning steering column (fixed).... this car has one too many error codes. Good thing I got it for a hand-me-down price. The only redeeming quality of this XC70 is its a wagon.
      07 Honda Accord V6 115k Silver - Great ride, Problem Free
      07 Honda Accord L4 110k Bronze - Great ride, Problem Free
      96 MB C220 330k (Parked) Silver - Great ride, Head gasket and wiring harness replaced at 315k (can't complain at that mileage)
      Check the front muffler, flex pipes and the upper torque mount. The torque mount when goes bad allows the engine to “tip” uncharacteristically which puts more flex on the flex pipes. The front mufflers crack and the leak at that spot sounds and feels like metal on metal,through the floor but also gives a growl, moan sound.
      2010 XC90 V8 - 113k miles
      2012 S60 T5 - 160k miles
      2009 C30 - Totaled. It ate a minivan at 35mph.
      2006 S40 - at 217k it was tired and needed too much.
      2008 XC90 3.2 - traded with 220,780 miles
      Member Oceans60R's Avatar
      May 2008
      Charlotte, NC
      Most common "growling" on acceleration I have seen is the Upper Torque Mount part number 30680708. Its on the passenger side, top of engine. The rubber bushing shrinks and just rattles. You can grab the aluminum mount and shake it, if it moves, it should probably be replaced. Lower hydraulic engine mounts can also cause this type of noise when they collapse.
      Here is a photo of a bad one.
      2011 S60 T6 Ember Black/Off Black, P* Tune, TDI-Tuning Box, DO88 Intercooler, IPD DP, Simons Sport Exhaust, IPD rear sway bar, H&R Springs, Bilstein B8's, 19" Polestar Wheels, 90mm Wheel Studs
      SwedeSpeed.com
      Junior Member bunnny's Avatar
      Jun 2017
      Brooklyn, NY
      Quote Originally Posted by Oceans60R View Post
      wondering if the above solutions apply to 2017 models, too?
    7. #5
      Member
      Mar 2018
      D.C. Metro Region
      For what it is worth, the 3.2 is known to be a bit of a noisy - growly engine. What you are hearing may just be its natural disposition. A torque rod mount failing at 30K would be highly unusual. Not out of the realm of possibility - just unusual.
      2009 XC90 3.2 AWD l Oyster Grey / Bi-Xenon / Dynaudio / BLIS / VNS / RSE / THULE Aeroblade
    8. #6
      Jul 2015
      Calgary
      I just took ours out for a look and definitely at the forward end it was quite loose. To me it looks as if it could be an age related thing whereby the rubber has just shrunk. I pumped some silicone all around the voids and we'll see how that goes. There is one in the Amazon cart if it does not work out.
      07 XC90 3.2
    9. #7
      May 2017
      Chicago & D.C. Metro
      Quote Originally Posted by voldog View Post
      Could you define "growling?"
      As others have already said, if there is a vibrating like sound or feel, then it could be related to the engine mounts/torque rod. If it is a smoother vibration growl more so heard not felt, then it could be the transmission, such as a shudder.
      If it is an air growl like someone installed an intake on a Honda Civic Si, then that could be the normal variable length intake "growling" when the intake flap changes to adjust for the acceleration in higher rpms. Like a VTEC in Hondas, the 3.2 also has cam profile switching, or second cam, it switches to in higher loads and rpms.
      2008 XC90 3.2 AWD - 148k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Bridgestone Dueler H/L Alenza Plus 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Amazon Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
      About the XC90 3.2 - The good, the bad, and the ugly
      Strut Recommendations based on your specific XC90
      Upgrade front end rebuild with OEM, aftermarket, and original parts
      The better transmission JWS 3309/T-IV fluid for your 5 or 6 speed
      Why it's better to use synthetic oil instead of conventional
    10. #8
      Jul 2015
      Calgary
      The upper torque link looks like it has quite a range of motion in the slot and to me a waste of money and resources to replace it because of a little rattling. My wife says it is nice and quiet now after the sealant fix.
      07 XC90 3.2
    11. #9
      May 2008
      Charlotte, NC
      Quote Originally Posted by vince1 View Post
      The noise is only another symptom. Because the bushing shrinks, there is excessive movement every time there is acceleration and deceleration, the engine rock more violently. It eventually will destroy the hydraulic engine mounts that are MUCH more expensive. So just because you don't hear it, its still bad.
      Other issues on these engines that can "growl". I only listed what I see the most in my first response just by what OP said. Also could be Sister uses cheap gas and you are hearing pre-ignition/detonation. Premium fuel is recommended, see the owners manual.
      Failing AC Compressors AC/Clutch
      Failing Belt Tensioner
      Failing Idler Pulley
      Failing one way clutch on REED unit
      Failing bearing in REED unit
      Failing one way clutch on alternator.
      Failing bearings in Alt.
      Low power steering fluid
      Failing water pump
      Failed hydraulic engine mounts
      Failed Strut mounts (although usually heard driving over rough road or bumps but you would be surprised how far some people let things go)
      Low Transmission Fluid/Bad Trans
      Low Oil
      Failed PCV Diaphragm (has more a high pitch squeal and may have misfires and a CEL)
      Those are just a couple of noise issues I see day to day.
      Can this apply to a 2017? someone asked, absolutely but the noise on those are more of a rattle on start-up and clunking when shifting gears from park to reverse or drive. Its a different part than the one I pictured but serves the same purpose. Not fixing it ruins the hydraulic mount underneath it fairly quickly. You'll know when the black hydraulic leaks out everywhere.
    12. #10
      May 2017
      Actually, the upper torque mount replacements already come a little loose (bushing). Besides the normal "wear" from use, it doesn't really shrink, but can compress. Unlike the T6, the 3.2 upper torque mount is encased in a metal slot, thus can rattle laterally, not just from the direction of the engine movement fore and aft.
      A LOT of the list you wrote is not isolated from ~30-60mph as the OP stated. The engine issues, like those components with bearings, would be heard in park if the engine was simply revved.
      We in the XC90 Gen 1 do not have 2017 models.
    13. #11
      Jul 2015
      Calgary
      Because of the easy way in which my wife drives the car I doubt that our engine mount has ever come close to the end of its travel in the torque mount slot. The silicone 'fix' has taken the rattling noise away. Next time I would try using a couple of pieces of tongue depressor and silicone them in on either end of the loose rubber piece.
      07 XC90 3.2
    14. Remove Advertisements
    Similar Threads
    1. Engine growling sound upon acceleration
      By B-Lou in forum General Volvo Discussions
      Last Post: 01-06-2018, 02:01 AM
    2. Droning/growling sound in '07 XC90
      By vulture in forum XC90 (2003 - 2014)
      Last Post: 12-19-2017, 05:08 PM
    3. Growling sound; s80 2007 awd v8 ??
      By SINCGARS in forum S80 (2007-2016)
      Last Post: 01-13-2013, 09:39 PM
    4. Replies: 2
      Last Post: 12-13-2011, 12:27 PM
    5. Strange growling noise from front pass side
      By t6tim in forum XC90 (2003 - 2014)
      Last Post: 08-13-2006, 02:30 PM
