TF-80SC auto trans manual shift problems
    Results 1 to 4 of 4
      Mar 2019
      2007 xc90 4.4L V8. In drive mode the transmission shifts fine and always has itís always had itís trans flushed every 40,000 miles and does not exhibit any of the problems with the valve body that some of these transmissions have however manual shift mode has started to act up it worked fine for many years but now itís doing funny things the valve body is not the problem does anyone know what may be the problem?
      I understand that there are a little shift paddles when you pull the shifter over to manual mode they pick your gear up or down I understand those can crack and break and do funny things I havenít gone into look yetbut sometimes it works Fine other times it does not this leads me to believe it may be a blue cheese problem,..corrosion on the connector for the little computer box thatís under the shifter I wonder if anyone out there has had this problem and knows how itís corrected
      May 2012
      Quote Originally Posted by Paul1963 View Post
      If you are referring to the shifter claw located underneath the shifter bezel, you will know immediately if the claw is broken. It doesn't change how the tranny drives, just makes the whole shift column difficult to operate. If the claw is broken, it doesn't want to stay in drive, it floats between drive and manual shifting. The shifter column also feels very loose in drive/manual. But the tranny will continue to operate normally.
      06 Volvo XC90 2.5
      05 Mazda RX8
      00 Aprilia RSV Mille
      95 Aprilia RS250 Chesterfield Edition
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      Define "doing funny things"
      2004 V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2006 & 2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R, 1999 F250 Powerstroke, 2005 TSX, 1997 Bonneville, 1998 Concorde
    5. #4
      Mar 2019
      The trans is fine til I go over to manual shift
      Then it will go into 1st sometimes or just go down a gear when I go over
      And wonít shift up or maybe it will
      Iíve never had it go into 1st at any more then 10-15 MOH but have heard horror stories
      It seems itís just a diff thing each time I try
      So Iím wondering if any of you have had this sort of issue and then maybe you know what you could do to correct it
    6. Remove Advertisements
    Similar Threads
    1. 2007 xc90 4.4L V8 TF-80SC auto trans manual shift mode problems
      By Paul1963 in forum XC90 (2003 - 2014)
      Last Post: 02-07-2020, 08:29 PM
    2. S60 T6 Geartronic Problems TF-80SC
      By SveniBenni in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 01-23-2018, 02:17 PM
    3. tf 80sc transgo shift kit, anyone used it to rebuilt their solenoids
      By bayerisheteknik in forum R Forum (2004-2007)
      Last Post: 11-14-2017, 04:52 PM
    4. TF-80SC trans temp
      By opelrick in forum OBD, CANBUS & Engine Management
      Last Post: 07-30-2017, 03:39 AM
    5. M66 & TF-80SC AWD (6spd Auto) Angle Gear Interchangability
      By Austin V70R in forum R Forum (2004-2007)
      Last Post: 11-19-2015, 08:43 AM
