Correct Torque Rod mount for P80 AWD
    Results 1 to 3 of 3
      Nov 2008
      Bend Oregon
      I'm placing an order with your Eeuro parts and they show this inexpensive poly mount that supposedly fits all P80 including all-wheel drive.
      Is this correct?
      I was under the impression that there was a different bolt pattern for P80 all-wheel drive than FWD.
      Also looking for opinions on quality of these mounts from Professional Parts Sweden.
      Thanks in advance.
      Sent from my Pixel 2 XL using Tapatalk
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      It’ll fit. Have one on the 2000 T5 swapped XC. To have it be perfect just punch out the small end bushing in the existing awd mount and swap the poly. The poly on the proparts Mount is acceptable quality, the aluminum casting not so much. I had one break for no apparent reason.
      2003 V70 T5 - Mystic/Graphite - M56LK - 201k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 292k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 174k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      Nov 2008
      Bend Oregon
      Quote Originally Posted by ScottishBrick View Post
      Wonderful. Thanks you as always.
    Similar Threads
    1. Correct torque rod mount for P80 AWD
      By PresseR in forum S70, V70 & V70XC (1998-2000)
      Last Post: 02-13-2020, 09:17 PM
    2. Engine Torque Rod Mount - subframe holes round or oval?
      By ritchj in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 10-03-2019, 08:58 PM
    3. Powerflex Yellow Insert for Volvo Upper Torque Mount Rod (New)
      By rallyr32 in forum FWD & AWD Parts For Sale
      Last Post: 08-16-2019, 04:49 PM
    4. 1998 V70 AWD transmission torque rod no longer available?
      By zhenya00 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 12-30-2015, 01:36 AM
    5. xc 90 Strut Brace Mount or Upper Torque Rod Bracket
      By slashbd in forum XC90 (2003 - 2014)
      Last Post: 12-24-2013, 10:23 AM
