Anyone take off the plastic engine covers to reduce heat build up?
    Results 1 to 3 of 3
      Mar 2019
      I’m a retired Audi tech and I can’t remember the old Audi Quattro‘s having vapor lock problems because the fuel line was just right up against the engine and it could be a nightmare and I’ve heard some guys take the engine covers off to allow the heat to escape that gets trapped under the plastic engine covers and they’re just cosmetic anyway has anyone done this?
      Member
      Aug 2017
      Aside from the occasional rodent nest I find under the covers, I've never seen a problem caused by any of the engine covers.
      May 2017
      Chicago & D.C. Metro
      No and heat like vapor lock is not an issue in the XC90. Remember, those covers are not just cosmetic or sound, but to help protect against the elements, such as water, salt, and dirt. I wouldn't want a wiring harness, ignition coil, or the like getting gunked up or wet.
      2008 XC90 3.2 AWD - 148k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Bridgestone Dueler H/L Alenza Plus 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Amazon Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
      About the XC90 3.2 - The good, the bad, and the ugly
      Strut Recommendations based on your specific XC90
      Upgrade front end rebuild with OEM, aftermarket, and original parts
      The better transmission JWS 3309/T-IV fluid for your 5 or 6 speed
      Why it's better to use synthetic oil instead of conventional
    Similar Threads
    1. Heat, heat, and more heat
      By cwielus in forum XC90 (SPA: 2016 - )
      Last Post: 12-18-2015, 10:21 AM
    2. Replies: 26
      Last Post: 08-16-2013, 10:31 PM
    3. Brunt Exhaust Valve-what causes the heat build up?
      By dave g in forum S70, V70 & V70XC (1998-2000)
      Last Post: 07-06-2009, 10:05 PM
    4. Plastic crossbar mount covers flew off while driving
      By engine in forum Overseas Delivery Forum
      Last Post: 05-08-2009, 12:25 PM
    5. Heat build up in the ECU compartment
      By Rangeball in forum R Forum (2004-2007)
      Last Post: 07-06-2006, 12:14 PM
