Engine Protection Plate upgrade - Does anyone have this installed?
    Results 1 to 12 of 12
      Nov 2019
      Link to the kit is here: https://usparts.volvocars.com/p/Volv...47/Kit063.html
      If anyone has this installed, can you let me know if you had the dealer install it or if you did the install yourself please...thanks
      Member lamarguy's Avatar
      Aug 2006
      Austin
      https://accessories.volvocars.com/en...CC-515841/2018
      Installation requires special tools, drill and rivet nut tool, for drilling out the car's existing holes and attaching the protective plate.
      You can do it yourself, but the required rivet nut tool lists for $300+.
      OSD '18 XC60 T8 Momentum - 22" 10-spoke wheels, lowered air suspension, strut tower bar, Stealth hitch
      Junior Member BigBang's Avatar
      Mar 2018
      World
      Quote Originally Posted by BLS1965 View Post
      Here is PDF installation Instruction and all what you need
      https://accessories.volvocars.com/en...CC-515841/2020
      You can buy the tool you need on Amazon for $40:
      https://www.amazon.com/s?k=rivet+nut...ref=nb_sb_noss
      2018 XC60 T5 R-Design
      SwedeSpeed.com
      Jan 2019
      Concord, MA
      I had it installed on our V90cc. Had the dealer install it while it was in for 10k mile service. I don't have the correct rivnut tool and didn't want to buy it to install this one thing, and was happy to let them do it.
      If the xc60 plate is the same as it is for the 90-series, just be aware that there's a revised part number as of 2020. They changed the NACA ducts from being a hard rubber/plastic that's riveted to the aluminum plate, to the NACA ducts being stamped into the aluminum plate itself.
    7. #5
      Junior Member Kranvagn's Avatar
      Nov 2018
      Silicon Valley, CA
      Yup I've got it, see it in detail in these two videos:
      I did remove it myself to fix the oil plug issue in the 2nd video, wasn't the worst thing in the world, but it's big and the washers are funky so having a helper really helps.
      2019 XC60 T8 Fusion Red R-Design - www.MotorSportUnPlugged.com -
    8. #6
      Junior Member p07r0457's Avatar
      Mar 2019
      $741.75 MSRP!?!?!???!
      No thanks!
    9. #7
      Junior Member rocketscience55's Avatar
      Mar 2017
      Washington D.C.
      Quote Originally Posted by p07r0457 View Post
      No thanks!
      Buy it from Tasca. Thats where I got mine for the C30
      https://www.tascaparts.com/oem-parts...g-pla-32207835
      2019 XC40 T4 FWD, Momentum with Premium and Vision Package - Hers
      2013 C30 Polestar #141/250, Mototech exhaust, Volvo Skid Plate, RacingBeat RSB, - His
      1997 Volvo 850 N/A with 240k, 1 owner, SOLD 2017
      2000 C70 Convertible 5sp HPT, SOLD 2011
    10. #8
      Mar 2018
      World
      Quote Originally Posted by rocketscience55 View Post
      It's a totally different part, it's not the same
      The first link is Part Number: Kit063, which has multiple parts
      What This Fits:
      This product fits 5 vehicle variants.
      Volvo: 1 models, 5 variants between 2018 and 2020.
      Volvo XC60 2018, 2019, 2020
      Volvo XC60 2.0l 4 cylinder Turbo 2018, 2019
    11. #9
      Mar 2017
      Washington D.C.
      Quote Originally Posted by BigBang View Post
      What This Fits:
      Based on the part numbers provided by the original link, we have the following part numbers in the Kit063:
      32207835 - skid plate
      32270862 - rivets and bolts needed to mount
      9512782 - silly Volvo rivet tool, like you said, use Amazon for this
      9814112 - silly Volvo Drill,
      Only the first two are necessary and through Tasca the total is $326.41 + $18.44 = $344.85
      Not sure why Volvo lists this as a kit, seems misleading to me
    12. #10
      Mar 2018
      World
      Thanks for the info. I did not check the individual parts
      It is strange that Volvo emphasizes that it is only for the XC60
      So for every other model according to Volvo there are other parts and tools
      What's even funnier, exist Kit056 for the XC90 with the same parts and for V90 Kit065
      https://usparts.volvocars.com/a/Volv...it_kit056.html
      https://usparts.volvocars.com/p/Volv...46/Kit065.html
      Same parts, different sets (Kit 056, 063, 065) and different prices
      Probably Volvo has someone clever to explain this difference
    13. #11
      Mar 2017
      Washington D.C.
      Maybe the riv-nuts are an M10 for the XC90 and a M8 for the V90? I'm still shocked they say you need a Volvo drill
      You think for an oil change they also list the tools needed...
    14. #12
      Mar 2018
      World
      But the catalog numbers for all three packages are the same
      When you look at MOUNTING KIT 32270862:
      This product fits 30 vehicle variants.
      Volvo: 4 models, 30 variants between 2016 and 2020
    15. Remove Advertisements
    Similar Threads
    1. Replies: 24
      Last Post: 01-12-2018, 04:35 PM
    2. Replies: 31
      Last Post: 10-01-2007, 05:43 PM
    3. Replies: 11
      Last Post: 02-03-2006, 03:32 PM
    4. Pros and cons on engine protection plate
      By RSElliott in forum XC90 (2003 - 2014)
      Last Post: 07-27-2003, 02:22 PM
    5. What paint protection does anyone have experience with?
      By pino in forum R Forum (2004-2007)
      Last Post: 06-09-2003, 08:56 AM
