Drive-E T6 Oil Change - Slightly Annoyed
    Results 1 to 13 of 13
      Dec 2019
      NY/NJ/MA
      Just changed did my first oil change with the V90 at 3800mi. IMO, the whole process is slightly more annoying than it has to be.
      1. Have to remove the entire underbody engine bay cover to access the oil filter and oil drain plug. Rather a PIA if you are doing it on a ramp or jackstands. Coming from BMWs, things are way easier with the Bavarians since the drain plug has its own access port that requires no tool to open and of course, the oil filters are on the top of the engines with all BMWs.
      2. Oil fill port is very restricted. You have to pour very very very slow to avoid spilling the oil out of the fill port. My bikes take in oil faster than this engine. Wonder why Volvo doesn't make the opening on the valve cover slightly bit larger. I can't imagine how anyone at the dealership has the patience for this without spilling the oil everywhere...
      09 BMW E92 335i: EFR 7670 Single Turbo / AP Racing / Wavetrac / TC Kline
      07 BMW R1200S: Akrapovic / Ohlins / Quickshifter
      19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization
      Junior Member Okidiver's Avatar
      Jan 2008
      Tampa...sometimes
      The dealers don't use bottles of oil, they have hoses with nozzles designed for the task...unless you bring in your own oil, then all bets are off...
      1. these engines are designed to heat up quickly and stay that way and
      2. little consideration is given to those performing their own maintenance these days
      You have patience; I'd be way more than slightly annoyed...
      Rapid Rick...I roll
      2008 C30 Matt Pearl Gold OSD-customized w/Elevate tune
      2015 V60 Seashell Metallic w/Platinum, BLIS, wood
      Dec 2007
      Quote Originally Posted by cloud9blue View Post
      I have a very simple solution - if your annoyed - have someone else do it.
      SwedeSpeed.com
      Dec 2019
      NY/NJ/MA
      Quote Originally Posted by GRUENDIG View Post
      well, that wont work because I am also OCD.
    7. #5
      Member lamarguy's Avatar
      Aug 2006
      Austin
      I thought it was easy on ramps. No complaints.
      I changed my oil at 1k miles (Pennzoil Ultra). Easier than my P1 S40, which had the filter on the top and required removing part of the air intake and using a couple of socket joints to unscrew the filter housing cap (located at a weird angle).
      OSD '18 XC60 T8 Momentum - 22" 10-spoke wheels, lowered air suspension, strut tower bar, Stealth hitch
    8. #6
      Member
      Aug 2017
      United States
      Regarding the slow fill, it has to do with the PCV. Disconnect the hose from the breather box and it will fill faster.
    9. #7
      Junior Member Mr Timewise's Avatar
      Apr 2017
      Hawthorn Woods, Illinois USA
      ^ Thank You, Tech!
    10. #8
      Member
      Aug 2017
      United States
      I should add that doesn't always happen. Seems to depend on temperature.
    11. #9
      Feb 2019
      Long Island NY
      Just wanted to say the same as Tech. I had no issue with the pouring speed. I guess heated garage helped.
    12. #10
      Dec 2019
      NY/NJ/MA
      Quote Originally Posted by Tech View Post
      wow, thanks! you happen to work in the Boston or NY area by any chance :P
    13. #11
      Dec 2019
      NY/NJ/MA
      Quote Originally Posted by lamarguy View Post
      I am sure the extra clearance on the XC helps
    14. #12
      Dec 2019
      NY/NJ/MA
      Interesting, well I was doing it at the driveway of inlaw house at NJ at around 40F ambient temp. Living between NYC and Boston these days, so that's about the only place I can wrench now...
      I guess next time I will warm up the oil bottles first.
    15. #13
      Member
      Aug 2017
      United States
      I meant engine temperature, not the temperature of the new oil.
    16. Remove Advertisements
    Similar Threads
    1. Ok to go slightly past the 10k mark on oil change?
      By stick_shift in forum XC90 (SPA: 2016 - )
      Last Post: 06-06-2018, 09:15 PM
    2. Annoyed with my R. Or maybe I am annoyed with the dealer....
      By arethusa71 in forum R Forum (2004-2007)
      Last Post: 04-23-2010, 11:04 PM
    3. Anyone else annoyed at Volvo's packaging strategies? V50 or S40?
      By Boxsterjoy in forum S40 & V50 (2005-2012)
      Last Post: 02-11-2006, 05:55 PM
    4. Anybody ever get annoyed by turn signals
      By Dharam66 in forum S40 & V50 (2005-2012)
      Last Post: 01-03-2006, 12:46 AM
    5. Replies: 9
      Last Post: 01-29-2005, 06:09 AM
