Since the R is trouble free, Project Escort
    Page 1 of 2 1 2 LastLast
    Results 1 to 35 of 49
      Aug 2018
      Idaho
      If not allowed then I suppose delete, but who doesn't like:
      A) Watching someone else spend their money
      B) Watching someone else bask in ignorance (I should have quit this project before I started)
      C) Engine build threads (more so a revival then a performance build)
      Running total on project: $$1466.00
      I always wanted one of these things in highschool, but they seemed to be fairly rare and getting more rare as the years went on, so when I found this one on the marketplace for 500.00 I decided to live my youthful lust for them in my mid 30's...
      So here is this bad decision when I got it home
      It would shoot flames out of the throttle body when I tried to start it with ether, the interior was terribly dirty, but I figured a good hazmat suit, a shop vac and some rags soaked in acetone should disinfect the thing enough to make it driveable.
      Car 400
      Gas to pick it up with truck and trailer 5 hours away 155.00
      Compression check showed dismal results....
      Cylinder 1=0 2=35 3=90 4=0, healthy it should read 130+ so I checked timing, timing was off two teeth at the crank, but that shouldn't have caused the numbers I am seeing. Given this is a NON interference motor I figured the valves didn't touch the pistons so I was safe there, or was I???
      Time to pull the motor
      Success, turns out separating the transmission in the car is a huge PITA, so I will certainly be installing them as a unit, if I don't give up on this hunk first...
      Motor out, several pounds of cat litter and bloody knuckles later, the engine is on a stand, as I am rotating the motor gravity and rotational force had become allies and were collaborating behind my back. The engine swung around and the poor distributor hit the I beam on the engine stand shattering in glorious fashion, sending the rotor and distributor bits across the garage...FFF
      I powered on... Getting the valve cover off, timing belt, head,and cams..
      I have to admit when I started this project, my budget was 1200.00 including the purchase price, this was going to be a cheap daily to screw around with and the escort GT notch on my belt... It's looking more expensive now, I have never seen a motor where every piston has seen some ****, but somehow held it together. I feel like they must have been giving eachother words of encouragement to just keep on going....
      I am also completely impressed the cylinders are not scored super bad, and there is still cross hatching... This motor is a trooper, it makes me want to save it even more, but 1200.00 will not do the job.
      Cylinder 1
      Cylinder 2
      Cylinder 3
      Cylinder 4
      My best guess is this thing over heated and the rings got too tight causing the pistons to crack/defecate... I am not sure how else to explain this damage...
      My rockauto cart is currently at 900.00 this includes everything to put the engine back together and a clutch, I have yet to complete purchase, what says the forum? Should I press on? If I go over budget then I am committed to finishing this thing, which is fine, I have considered raising the budget to 2k, but I still have to wonder what other surprises this obviously neglected GT has hidden in and around the other moving bits...
      Senior Member Wayne T5's Avatar
      Nov 2002
      Russell Twp, OH
      Wow, that's quite the project, good for you for taking it on.
      After looking at that motor my gut reaction would be to just find another motor to put in it but I'm saying that without knowing how hard it would be track down. Maybe there's a motor from a later or different model altogether that would work.
      Past: '94 854, '99 S70 T5 SE, '99 S70 GLT, '04 S60R M, '12 S60 T5, '13 S60 T5, '15 S60 RD, '05 V70R GT
      Present: '95 854 T-5R, '06 XC70, '15 XC70 T6, '15.5 XC60 T6, '16 V60 P*
      Aug 2018
      Idaho
      Quote Originally Posted by Wayne T5 View Post
      Or bad for me
      A new motor is 2k+
      I don't have enough interest in pulling another ???? motor only to find it needs work too, or going through pulling one on my back in a junk yard... It's either save this one or call a recycler and eat 300.00
      SwedeSpeed.com
      Junior Member b5v6's Avatar
      Sep 2004
      San Diego, CA
      Go aftermarket rods and Pistons, change compression, and give it a little extra go
      Instagram: @oliepyle
      '05 S60R - 2.4R, RaceS60R FMIC, RaceS60R Downpipe, SPEC LWFW/Stage 3 clutch, Elevate upper mount, Forge CBV, Phuzzy HDTCV, Eibach, IPD Sways, Powerflex/Superflex CA bushings, JVC M730 Head Unit (Android Auto, Subwoofer, Back Up Camera)
      '99 Audi A4 1.8T Stage 3...
    7. #5
      Aug 2018
      Idaho
      Pistons out...
      Couple bearings from three different rods
      Close up of the worst
      Crank looks okay so far, light scoring, going to see if a shop can polish it out, or what they think. What they say will depend on the direction I take...
    8. #6
      Nov 2013
      Barrie on Canada
      Why is this on the volvo r form?
    9. #7
      Aug 2018
      Idaho
      Because you 5uckers dont build cars anymore, report my thread if it hurts your feelers.
    10. #8
      Aug 2018
      Idaho
      Machinist said the crank looks like it will take a polish and be good.
      Block looks good but he'll have to run a few more tests, looks like I can reuse the rods, he'll call if there are any issues.
      Put the project next to my other project, R cameo to keep cupdriver91 happy.
    11. #9
      Member
      Feb 2007
      Grosse Pointe Farms, MI
      What year? I had an 88 GT as my daily back in high school/college. $500 car missing front end forward of radiator as it was sheared off in an accident, but the car was surprisingly straight and mechanically sound. It was white with the grey sport interior and sunroof and of course 5 spd manual. Quick trip to the local pizza delivery guys Escort graveyard and I had a front end again...I worked at a pizzeria and everyone drove an Escort until it died then they parked it in the "graveyard" for parts for their next Escort. I rattle canned the front end and sprayed a fresh coat every 6 months or so. Car was far from perfect but it was cool and fun to drive and very reliable. I learned a lot from brake jobs to clutch. Good car for a kid my age at that time. Parts were cheap too.
      07 S60R Electric Slvr/Nordkap 6MT Darton Sleeved/Rods/Pistons, RaceS60R FMIC, IPD Sways, Spec Stg3+ SMF, PDV Collar Sleeve, EFR7163, PM3, Aeromotive 340 fp, ID1050x, RS4 MAF, Devils Own Meth & Contrast Tune
      01 Audi S4, Tial 605's, built engine, etc
      93 Mustang Cobra, Incon Twin Turbo 347 Dart, etc
    12. #10
      Aug 2018
      Idaho
      Quote Originally Posted by ElementR View Post
      1991
      Supposedly these engines don't die easy, so who knows what chipped all four pistons. I don't have a pizza boy grave yard, but I do have the internet.
    13. #11
      Feb 2014
      New Orleans, LA
    14. #12
      Aug 2018
      Idaho
      Quote Originally Posted by mobeus View Post
      two reasons:
      Disposable income
      R is problem free and it feels weird not wrenching on things
    15. #13
      Member HunterBD's Avatar
      Jun 2011
      Auburn
      No offense I thought this was a board about Volvo’s and not Found On Road Dead cars!! Cant you discuss it somewhere else, like a FORD site. Sorry but I hate these cars. They are [email protected] Never seen a good ford since the early 60’s. Good luck on your escort. I’ll continue to post about Volvo related issues.
      05 VR GT Titanium Grey/Nordakp, sunroof, Winter Package, Premium sound with Volvo Sub. VST rear brace, Ultra Racing front strut brace. iPD Sways and other little upgrades they have. EST DP with Touring Exhaust.
    16. #14
      Feb 2014
      New Orleans, LA
      Quote Originally Posted by kTaLgsTo View Post
      two reasons:
      Disposable income
      Why not an S40? That's basically a Ford anyway.
    17. #15
      Aug 2018
      Idaho
      Quote Originally Posted by HunterBD View Post
      uh, we are all driving fords guys, hate to break it to you... But I own four Ford's, 2 p2rs an ltd and this escort. I think the Volvo purist talk should be over in the 240 section
    18. #16
      Aug 2018
      Idaho
      Also no offense taken, Mercedes Benz guys hate when I call my wife's jeep crd a Benz, vehicular collaboration tends to irk some people...
    19. #17
      Member Chicago_Wagon's Avatar
      Jan 2016
      Chicago, IL
      Not being the first people to live on the land has never stopped Americans from telling others to go back home, LOL. Maybe as a non-P2 owner, I’m not allowed to have an opinion about the “R Forum”.
      Just out of high school I worked with a guy that owned an Escort from this era and all he did was add gas. Not even oil changes. It’s been too long ago now to remember how many years went by, but I quit that job after a couple years and it was still running without issue. It was crazy.
      Current - 2000 V70R Venetian Red Pearl
      Past - 1998 V70 XC Emerald Green Metallic
      RIP - 1987 Mazda RX-7 White/Red (first car, many speeding tickets, blown rotary engine)
    20. #18
      Aug 2018
      Idaho
      Quote Originally Posted by Chicago_Wagon View Post
      This car was abused, mismatched rotten tires, metal on metal brakes...
      I think he only stopped driving it because it wouldn't start.
      So it appears all escort owners just drove their car and nothing else.
      Machinist called today and said the motor looks like it ran with a blown head gasket for many miles.
      I'm going to bring it back, I might even try to install some R parts on it just to be cheeky.
    21. #19
      Oct 2016
      Victoria BC Canada
      So there is no chance of fitting an R motor in it? I mean, an Escort is basically a Focus which is basically an R, right?
      | 04 V70R Titanium Grey/Nordkap M66 | Hilton Stage 2 | Mototec DP & Touring Exhaust | ERST Springs | Summer Mode: 18" Fast FC04A | Winter Mode: 18" Pegs |
    22. #20
      Aug 2018
      Idaho
      Quote Originally Posted by Enraged View Post
      I have a complete R swap including ecu, and I thought about it when this escort motor was looking uglier the deeper I got, but it turns out the block is okay...
      So it's just going to be restored, then I'm going to use it to teach the wife the long lost art of driving a manual.
    23. #21
      Member
      Feb 2007
      Last time my wife drove a manual trans was the first time... and my cars and I are thankful for that.
    24. #22
      Aug 2018
      Idaho
      My wife cried last time I tried, but I don't care about this car or it's clutch, so once it's drive-able she won't be able to hurt it any worse than the previous owner did....
      Put in my rockauto order today... 571.00
    25. #23
      Mar 2013
      Arizona
      Ya know, Ford made another vehicle back then with the letters "GT" at the end of the name, and they are more plentiful, cheaper to build, make tons more power (both before and after mods), and are basically all around cooler on EVERY level.
      Just sayin.
      2006 V70R MT
      Sonic Blue / Gobi
      Original owner
    26. #24
      Aug 2018
      Idaho
      Quote Originally Posted by Phoenix R View Post
      Just sayin.
      I prefer the rare but undesirable approach.
      127 hp should be just about right for this build, I have the R if I get bored.
    27. #25
      Member
      Feb 2007
      Just sayin.
      And a far bigger money pit, trust me.... I know!
    28. #26
      Member esmith813's Avatar
      May 2012
      Poconos, PA
      Nice project! Careful on saying "trouble free" though. I recently picked up another project for the same reason, and now of course all the trouble is arising. haha
      My wife has been trying to learn stick (read:I've been forcing my wife to learn). Her XC was down for two days recently and she was forced to take one of the other cars (all manual). After those two days, she's way more confident and has even asked to take the TDI again. I was doubtful the night before during her refresher when she missed 3rd and went back into 1st going about 15-20 MPH - that hurt. haha
      2006 S60R MT Sonic Blue with Atacama - Garage Queen
      2008 XC90 V8 Sport Passion Red with Off Black - Hers
      2015 VW Golf Sportwagen TDI MT, 2001 Jeep Wrangler 4.0L MT 60th Anniversary Edition
      Previously: 2010 S80 V8, 2006 V70R MT, 2004 S60R MT, 1993 245 NA, 2006 XC90 V8, 2002 Dakota V8 MT
    29. #27
      Aug 2018
      Idaho
      Cool that she is getting confident with a manual.
      My wife partially doesn't care, partially doesn't understand the concept.
      So it will be an uphill battle.
    30. #28
      Mar 2013
      Arizona
      It's the exact opposite for me - the wife wanted a manual trans (she had/still has a Jeep Wrangler manual trans) so we had to special order the VR as there weren't any to be found on dealership lots across the country.
      2006 V70R MT
      Sonic Blue / Gobi
      Original owner
    31. #29
      Global Moderator R-Pow3R3d's Avatar
      Apr 2015
      Pittsburgh, PA
      Moved to "Car Lounge" with extended redirect listing in "R Forum" since it's captured a fair amount of interest here.
      2004 V70R MT TiGray/Nordkap - Replica 18" Pegs - Handbrake Mod
      2007 XC90 V8 Sport Passion Red/Off-Black - Serpentine Belt, Tensioner & Idler Pulleys - Spark Plug Replacement - Y-Pipe Replacement
      1990 745 Turbo Intercooler White/Beige
      2006 & 2007 XC70
      VIDA/DICE Owner - SS Lurker Since 2009 - '06-'07 Transmission Valve Body Info - SR/VR Failing Throttle Body
      Current Non-Volvo: 2007 VTX 1800 F3, 2002 VT750DC
      Previous: 2006 S60R
    32. #30
      Aug 2018
      Idaho
      Picked up Ford's 1991 version of VIDA and started some work on the Rods...
      Found one of the Rods was put in backwards from the factory, which really shouldn't matter, but I thought it was an oddity... Guess I'll keep it that way since it's ran 100k+ miles this way...
      Installed some Chinese pistons
    33. #31
      Aug 2018
      Idaho
      Crank is in!!!
    34. #32
      Aug 2018
      Idaho
      Spins around real nicely!
      A lot of people seem to complain about this ring compressor, but for 9.00 what do you expect?? It's a cheap piece of crap and it takes extra steps and caution when inserting the pistons, just use some patience.
    35. #33
      Aug 2018
      Idaho
      Well the R is no longer trouble free.....
      Insurance company is wanting to scrap it out, I am fighting it... but what a bummer...
    36. #34
      Senior Member ZZZZZZZ's Avatar
      Aug 2005
      Northern MD
      Tooth and nail, kT. Tooth and nail.
      "The Real IPD" - ZZZZZZZ's thread
      2007 Passion Red/Gobi VRgt; 2005 Silver/Beige Leather S60 2.5T AWD; 2002 Silver/Off black leather V70XC
      Past: 1999 Tropic Blue/Green/Oak leather V70 (NAa); Mom traded 1975 Maroon/Maroon leather 164E
    37. #35
      Member Exocet's Avatar
      Nov 2017
      Southern Tier NY
      Or bad for me
      A new motor is 2k+
      On US-6, west of Troy, PA is a house with a few old Escorts in the back yard. A white GT, a yellow one, plus maybe one or two more. They look like they've been sitting for a while.
      2007 Volvo V70 2.5T - Mine
      2008 Nissan Titan SE 4x4, Crew Cab, Long Bed - Also Mine
      2012 Toyota Camry LE, 2.4 - Wife's
      2003 Mazda Protege5, 2.0 - Daughter #1
      2010 Mazda 6 Grand Touring, 2.5 - Daughter #2
    38. Remove Advertisements
    Similar Threads
    1. 2005 T5 battery trouble? heater trouble?
      By 88c900t in forum S40 & V50 (2005-2012)
      Last Post: 08-13-2015, 08:54 PM
    2. 5.5 years of trouble-free ownership comes to an end
      By PB11 in forum R Forum (2004-2007)
      Last Post: 06-18-2009, 05:57 PM
    3. Free Volvo Free Volvo Free Volvo
      By Chilled Man in forum FWD & AWD Cars For Sale
      Last Post: 05-18-2009, 08:51 PM
    4. Replies: 0
      Last Post: 07-02-2008, 11:22 AM
    5. Free Volvo Free Volvo Free Volvo
      Last Post: 06-09-2008, 12:05 PM
