PCV breather box leaking?
    Results 1 to 7 of 7
      Feb 2016
      Hi to everyone.
      I've changed my oil with new PCV breather box(Oil filter housing or Oil separator or..whatever it's called) few weeks ago, and drove for about 300 miles now.
      But I see this.
      (sorry about the images. you can view them from
      https://drive.google.com/drive/folde...QAJAOnmg1huPc3)
      It seems that the plastic (cover, is it?) on top of the aluminum body is not well sealed.
      Is this normal or do I need to ask FCP for a replacement?
      Haven't seen any reports that this PCV breather box is very easy to make oil leaks, just've seen everything related to clogging, diaphragm..
      Believe me I didn't spill any oil when filling.
      Junior Member Hector_Volvo's Avatar
      Apr 2013
      Redlands CA
      We can’t see your pictures.
      Feb 2016
      Quote Originally Posted by Hector_Volvo View Post
      Sorry.. I’ve added a link to share via google. https://drive.google.com/drive/folde...QAJAOnmg1huPc3
      SwedeSpeed.com
      Member Oceans60R's Avatar
      May 2008
      Charlotte, NC
      Looks like its leaking. I would warranty that for another.
      2011 S60 T6 Ember Black/Off Black, P* Tune, TDI-Tuning Box, DO88 Intercooler, IPD DP, Simons Sport Exhaust, IPD rear sway bar, H&R Springs, Bilstein B8's, 19" Polestar Wheels, 90mm Wheel Studs
    7. #5
      Member AutoGeek's Avatar
      Jan 2008
      MD, Howard Co.
      I had thought they only failed with the tell-tail squealing. However, mine started leaking a while before it started squealing.
      2005 V50 T5 FWD M66 Passion Red (Radio Flyer) Bilstein HD, ECU spacer, Snabb Turbo Pipe
      1998 V70 NA - Sold, 2002 S40 1.9T - R.I.P., 2005 V50 T5 - RIP
      Remember kids, Speed doesn't kill ... impact does!
    8. #6
      Feb 2016
      Quote Originally Posted by Oceans60R View Post
      It stopped leaking then.. I wonder why and nobody around me knows the answer, so I'll just have to check regularly and see if it goes worse.
    9. #7
      Feb 2016
      Quote Originally Posted by AutoGeek View Post
      Mine doesn't squeal, it's a new one I've replaced. Still doesn't squeal after adding more mileage(+900).
    10. Remove Advertisements
    Similar Threads
    1. Breather box (PCV) folly
      By JRL in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 02-16-2015, 10:22 PM
    2. It finally happened - PCV/breather box
      By Seven in forum S40 & V50 (2005-2012)
      Last Post: 08-14-2012, 04:41 PM
    3. Volvo S80 OEM oil trap breather PCV box and intake manifold gasket NEW
      By anh35conde in forum FWD & AWD Parts For Sale
      Last Post: 06-24-2012, 01:29 PM
    4. Breather box... Flame box... PCV System
      By hotshift13 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 01-24-2011, 02:16 PM
    5. Replies: 2
      Last Post: 11-11-2003, 10:15 PM
