Jump starting my xc90
    Results 1 to 12 of 12
      Feb 2020
      Canadian border vermont
      25 below a few days ago and I needed to use my booster box. I can only reach the rear hatch when Iím parked in the garage but the manual says to boost from the engine compartment. Can I boost the battery directly from the battery in the rear or not, and if not why not? It certainly would make a better connection point. Thanks! This is a 2005 xc90.
      Junior Member CDN XC90's Avatar
      Oct 2017
      Ottawa, ON, Canada
      You can definitely boost from the battery. However, to me, it would be more work to uncover the battery than connecting to the terminals under the hood.
      When I put the battery on the charger lately, I have used the under hood connections as well.
      2006 XC90 2.5T AWD - Contrast Works Stage 2 tune with Eco Enhance mode, Snabb fresh air pipe and downpipe, custom triple resonated catback, HEICO (BMC) sport air filter, Bilstein B4 front struts with HEICO rear struts and lowering springs, IPD Swaybars, strut brace conversion kit, and subframe bushing inserts. Fast FC05 20x8.5 with 255/45/20 Conti DWS06. Falken HS449 235/65/17 winters. JL 500/1 with Pioneer TS-SWX2502 subwoofer under cargo tray. LED low/hi beams, Tuxmats.
      Feb 2020
      Thanks! Iíve never owned a car that was so electrically quirky. I enjoy it a lot but Iím terrified of frying something expensive.The sorting process is centered in the electrical system. I would love to have available a readout of how it is designed, and why it was designed the way it is. My Mercedes is odd, but comfortably rational when you understand it. This is some other level of crazy.
      The point of boosting from the back end is that I canít access the front when parked in the garage, itís too huge.
      May 2018
      Southeast Michigan
      I've boosted the car from both ends. Both work. If one is better, I would guess it would be from the front, since that's closer to the starter, but I doubt there's a measurable difference.
      Just wondering....is it possible for you to back into the garage, thus having easy access to the engine compartment? Might save some fiddling with tools and all to get to the battery on a bitter cold morning.
      2005 XC90 V8, 230k miles and no plans to stop
      D.C. Metro Region
      Quote Originally Posted by CDN XC90 View Post
      l.
      I was going to say the same thing. Far more effort and diddling around removing bolts just to have access to the terminal. No thanks.
      2009 XC90 3.2 AWD l Oyster Grey / Bi-Xenon / Dynaudio / BLIS / VNS / RSE / THULE Aeroblade
      Feb 2020
      Itís an uphill approach, icy and the door is 8 ft wide, so itís a struggle to back into with a wide body car, especially with all the tractor parts lining the sides! I tried the front attachment points on the battery but felt like I wasnít getting good contact with my booster box clamps in the space provided. I considered making a copper extension on the positive point, and I might still do that. The solution Iím using right now is to stay home when itís cold out. being retired has its benefits, and thatís a big one.
      Oct 2017
      New Hampshire
      How about getting a small battery tender, or is a fully charged battery still no enough? What oil are you running? -25C isn't all that cold... (Never mind, I see you're on the Fahrenheit side of the boarder.) How about a block heater, or a heated garage! Make working on the tractors more pleasant, too!
      John C
      2011 XC90 3.2 173,000 miles and counting...
      Feb 2020
      This is a new to me car. It has 150k on the odo, and needs a certain amount of sorting. My plan right now is to get through winter and look at the starter this summer which I think might be dragging some. if it checks out as good, then a tank heater would be in order. Is there a recommended service interval on the spark plugs here?
      Oct 2017
      New Hampshire
      Quote Originally Posted by Vtmbz View Post
      75,000 miles
      John C
      Oct 2017
      Ottawa, ON, Canada
      Clean the under hood positive terminal perhaps. I expect the connection issues were more likely the ground rather than the positive...
      If you can access the hood, you should definitely be able to get a proper boost from there.
      Feb 2020
      Prize winner! Tried a start yesterday with dead battery and booster box in the engine compartment. For the ground I used a fresh terminal that was installed earlier on the drivers fender grounding path. That boosted well.
      Oct 2017
      Ottawa, ON, Canada
      Good to hear.
      Sounds like you may want to put a charger on the battery to top it up. I charge now from the under hood connections as well when needed.
    15. Remove Advertisements
    1. Jump starting using an S/V90 for power
      By porschie356 in forum S90 & V90, V90CC (SPA: 2017 - )
      Last Post: 12-11-2018, 12:07 PM
    2. Charging System Failure after jump starting...
      By Crispin in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 09-13-2017, 06:22 AM
    3. Had to jump start my wifes Mazda with the Volvo....
      By my2ndimport in forum R Forum (2004-2007)
      Last Post: 08-04-2010, 05:39 AM
    4. Hi/Lo beam bulb cost & jump starting your R
      By flybynight in forum R Forum (2004-2007)
      Last Post: 09-23-2009, 08:57 AM
    5. Tallest curb an XC90 can jump?
      By Johnny Cakes in forum XC90 (2003 - 2014)
      Last Post: 08-16-2004, 02:19 PM
