Suspension / Wheel Set ups - Let's see yours - Page 4
    Page 4 of 4 FirstFirst 1 2 3 4
    Results 106 to 129 of 129
    1. #106
      Member p.rico's Avatar
      Wilmington, DE
      Quote Originally Posted by MidnightSnooze View Post
      I dont know how you guys are managing with spacers and high offset wheels. The Bors are +55, if i went out another 10mm id be scrubbing everywhere
      Lower series tires. Or at least in my case, actual spec'd series tires. I presume the 2015.5's like yours are on the 235/40R19's or the 235/45R18's? I ran into the same problem with the 235/45R18, I could not run a spacer at all and could not fit a single digit between the fender liner and the tire sidewall. The "proper" sized tire for my 2012 fit perfectly fine though.
      2012 S60 T6 AWD - Vibrant Copper - Premium Package - Climate Package - Multimedia Package - BLIS - Polestar Optimization + Mods galore
      Running intro/install/DIY thread: https://forums.swedespeed.com/showthr...w-S60-T6-Owner!
      Apr 2016
      Australia
      Quote Originally Posted by p.rico View Post
      Im on 245/45/R19 at the moment and the squarer profile of the Pilot Sports probably doesn't help. But jeez, spacers and offset changes, i cant help but think you must be scrubbing somewhere.
      2015.5 V60 T5e -
      Polestar Performance Tune, Exhaust and Intake - Twin Piston Brake Conversion - SS lines - H&R Springs - IPD Rear Sway Bar
    4. #108
      Wilmington, DE
      Is that a typo? If not, that's a huge setup (over 2.25" larger diameter from my 235/40R18).
      https://www.tacomaworld.com/tirecalc...0r18-245-45r19
      Assuming it is, and you meant 40, that's still a 1.3" diameter difference from my 235/40R18.
      https://www.tacomaworld.com/tirecalc...0r18-245-40r19
      My oversized 235/45R18 setup is more comparable to that 245/40R19 size, and I could not run a +40 offset with it. I didn't try +45 offset, although that might have fit.
      https://www.tacomaworld.com/tirecalc...5r18-245-40r19
      Dec 2019
      Top of VA
      That was my thinking as well, the 19's I put on yesterday are 235/40R19, if I had put on 45 profile tires then I am pretty sure they would be rubbing. +45 offset and an 8.5" wheel, at least looking at what I now have, is likely going to be the maximum you can fit without rubbing or doing things like rolling the fenders.
      Of course, now I want to pick up some H&R springs for mine to close the wheel gap a little, but for now that can wait.
    7. #110
      Alexandria, VA
      I'm having tires mounted right now on new 19x8 wheels. The tires I chose are Nokian Zline A/S at 245/40/19. Hopefully they will fit without rubbing on R Design springs. I currently have 10mm spacers in front and 15mm spacers on the rear, but I have no idea if they will be useable. Any guesses?
      Sent from my HD1907 using Tapatalk
      2015.5 V60
      1987 Chevy El Camino
      1983 Chevy Caprice Classic Wagon
      2008 C30 R Design - SOLD
      1998 V70 T5 Manual - SOLD
      1998 V70 - Sold
      1992 244 - Sold
      1987 245 - Sold
      1983 244 - Sold
    8. #111
      Alexandria, VA
      Here it is with the new wheels.
      2015.5 Sport Chassis (R Design height)
      Wheels are 19x8 55mm offset.
      Nokian Zline AS 245/40/19
      15mm spacers in the rear
      No rubbing.
      And finally no vibrations from the wheels and tires. I wish they were a lighter color, and I may change them soon. They are Ford Performance flow formed aluminum and weigh 23.25 pounds each. Best part is they are about $175 each.
      2015.5 V60
      1998 V70 - Sold
      1992 244 - Sold
      1987 245 - Sold
      1983 244 - Sold
    9. #112
      Dec 2019
      Top of VA
      Looks great 👍
    10. #113
      Apr 2016
      Australia
      Yep, sorry, typo. 245/40/R19
      2015.5 V60 T5e -
    11. #114
      Alexandria, VA
      Quote Originally Posted by abcdefghii View Post
      Looks great 👍
      Thanks. I'm not sold on the color, but they should work just fine. Now I need to figure out if I am going to sell the Bors or hold on to them.
      2015.5 V60
      1998 V70 - Sold
      1992 244 - Sold
      1987 245 - Sold
      1983 244 - Sold
    12. #115
      Sep 2020
      Did some googling to find those wheels, looks like they are the Focus RS ford perf wheels? Only thing Is when I find them they show $209 each and 30lbs each?
      https://www.fordracingparts.com/part/M-1007-FST1908MG
      Where did you buy yours? Also curious what the stock Bohr wheels weigh as that’s what’s on my car now.
      Thanks for your help!
      Quote Originally Posted by Seaway View Post
      No rubbing.
    13. #116
      Alexandria, VA
      Quote Originally Posted by Lucahemi View Post
      Where did you buy yours? Also curious what the stock Bohr wheels weigh as thatís whatís on my car now.
      Yes, that's them. I bought mine at Steeda.com for $179 each delivered. Below are the specs for the wheels from Tirerack.com which matches what my bathroom scale showed.
      I haven't weighed the Bors yet but will at some point this weekend. From what I remember, they weigh 27 or 28 pounds.
      2015.5 V60
      1998 V70 - Sold
      1992 244 - Sold
      1987 245 - Sold
      1983 244 - Sold
    14. #117
      Sep 2020
      Awesome thanks’! I’m in canada and looking to get a summer/track setup and keep the Bors for winter. These look like the perfect option for lightweight, strong , and affordable wheels! Were spacers necessary?
    15. #118
      Alexandria, VA
      Awesome thanksí! Iím in canada and looking to get a summer/track setup and keep the Bors for winter. These look like the perfect option for lightweight, strong , and affordable wheels! Were spacers necessary?
      Spacers are definitely not necessary. The wheels have the exact same specs as the Bors as far as offset and size are concerned.
      2015.5 V60
      1998 V70 - Sold
      1992 244 - Sold
      1987 245 - Sold
      1983 244 - Sold
    16. #119
      Sep 2020
      Hello everyone,
      Just put on new wheels and looking to drop the car a little bit. Based on what Iíve read here, the H&R lowering springs seems like the way to go. Is there a specific kit of springs?
      235/35/19
    17. #120
      Junior Member fakejarr's Avatar
      Aug 2020
      2012 S60 T5
      Wheels- 18X7.5, Take off set from a 2018 XC60
      Tires- 225,40
      Spacers- 15mm
      Suspension- H&R Sport Springs, Bilstein B8 HD Sport Shocks and Struts
      Ride Height- What it should've been from the factory
      Any Rubbing?- Nope
    18. #121
      Wilmington, DE
      Quote Originally Posted by fakejarr View Post
      I was looking at those wheels in some classified threads here recently. They are an intriguing design. My only gripe was the rim width being 7.5". Looks good!
      Any specific reason that you went with the 225 mm? Most people do tell you to go to 225 mm on a 7" or so wheel, but 235 mm is what the XC60 came with, just for future reference.
    19. #122
      Wilmington, DE
      Quote Originally Posted by rdvs View Post
      Hello everyone,
      235/35/19
      You'll want to grab the H&R 28889-2.
      It is for S60 (both T5/T6 models).
    20. #123
      Sep 2020
      Thanks. Those were the option from IPD. Now Iím considering shocks when I know I shouldnít.
    21. #124
      Aug 2020
      Right. I went with 225 because I was able to get a deal on the tires. I planned on going with 235 but, couldn't pass up the deal. All together, I was able to get the wheels and tires for about the same cost as just a set of four tires of the same quality.
    22. #125
      Aug 2020
      Check around on other sites. I ordered my springs through IPD and had to end up cancelling the order because they weren't in stock. This was a few weeks ago. At least call IPD first. They have pretty good phone service.
    23. #126
      Sep 2020
      I called the shop that did my wheels and apparently, I declined the springs when I purchased the wheels. They have the springs in stock.
    24. #127
      Wilmington, DE
      Depends... if you are going to get springs, and your front struts have a lot of miles on them, I'd replace the struts and definitely the strut bearing (if not whole bearing/mount assembly). Not worth going through all the trouble of getting the struts out if you have to do it again later due to a blown strut or a blow strut mount bearing.
    25. #128
      Sep 2020
      Itís currently at 75k. I made an appointment to do the springs with the wheel guy, but struts are not in the budget at the moment. Iíll have them take a look at it and if I have to do it now, then I guess Iíll get it done.
      Thanks for the info.
    26. #129
      Sep 2020
      Hey all, I have a 2015.5 s60 t6 w/ sport chassis. Looking to buy a set of track/autox wheels and tires. Do you reckon these will clear with no issues? Added pic of car for reference. I have the stock 19 Bors
    27. Remove Advertisements
    1. Need wheel ideas! Let me see your wheels!
      By Bryce Anderson in forum S60 (2001-2010)
      Last Post: 05-26-2017, 11:40 PM
    2. Suspension set ups...
      By mrwho2 in forum C70 (1998-2004)
      Last Post: 07-08-2008, 07:53 PM
    3. New Rims, Can I See Yours?
      By magnato1 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 02-15-2008, 07:41 AM
    4. Let it snow, let it snow, let it snow...
      By R Kelly in forum R Forum (2004-2007)
      Last Post: 11-27-2005, 12:07 PM
    5. What intake/air filter set ups are available?
      By stlvinny in forum R Forum (2004-2007)
      Last Post: 08-26-2004, 01:46 AM
