Had nothing to do today
    Results 1 to 24 of 24
      Feb 2019
      Long Island NY
      So I added some color to otherwise boring rubber.
      Junior Member choochjb's Avatar
      Jul 2019
      NC, USA
      Nice. Did you hand paint it?
      New Daily Driver: 2018 V90 T6 R-Design - P* Tuned, Passion Red
      Old Daily Driver: 2008 VW MKV GTI - APR Tuned, Candy White
      Backup/Hauler: 2019 Subaru Ascent - LP Aventure Lifted, Abyss Blue Pearl
      Feb 2019
      Long Island NY
      Vinyl wrap.
      SwedeSpeed.com
      Junior Member stocis's Avatar
      Oct 2019
      Cyprus
      Very nice indeed
      Current: 2020 Volvo XC60 R-Design, 2018 Volvo XC40 R-Design
      Previous: 2009 Volvo C70, 2006 Volvo XC60, 2003 Saab 9-5, 1999 Mitsubishi FTO, 1998 Land Rover Freelander, 1995 Suzuki Swift Sedan
    7. #5
      Dec 2017
      Curious why the charging, doing other things that required car to be on but no engine running? Thanks
      Sent from my SM-G950W using Tapatalk
      2018 V90 CC T6 Polestar (Pine Grey Metallic)
    8. #6
      Feb 2019
      Long Island NY
      It’s the fully automatic one. Since the car isn’t a daily driver the battery is maintained by ctek when not driven. I had good luck doing this on all of my previous cars where the battery lives strong after 7+ years. And obviously everyone’s favorite S/S works with the firs stop I make. Its in heated garage so no need for remote start.
    9. #7
      Dec 2007
      Quote Originally Posted by rkohou View Post
      I brought my connection thru the front grill so you never have to open the hood. Comes thru with a water proof push connector & cap. Quick & easy. Last battery made it to 13 years and I only replaced it because of a small weep.
      By the way - nice detail
    10. #8
      Feb 2019
      Long Island NY
      I’m waiting for the extender to ctek to do the same. Have the original installed on my old 535. Great chargers.
      Thank you for the thumbs up.
    11. #9
      Junior Member SeabeckS's Avatar
      Nov 2017
      Seabeck, WA, USA
      Those ctek chargers are great. Had problems with battery maintenance on a BMW motorcycle. Replacing batteries on that machine was a real PITA. problem solved with a ctek charger.
    12. #10
      Jan 2018
      Cornwall, NY
      Which of the many Ctek chargers do you use for a V90/S90?
    13. #11
      Feb 2019
      Long Island NY
      CTEK (56-353) MULTI US 7002 12-Volt Battery Charger https://www.amazon.com/dp/B000FRLO9Y..._j3xvEb4RVTH95
    14. #12
      Junior Member 808dakine's Avatar
      May 2018
      Hawaii
      Love the paint job! The vinyl wrap stays on with just the existing adhesive or did you use something additionally? BTW, which model of CTEK are you using? I have the same issue with infrequent use.
    15. #13
      Feb 2019
      Long Island NY
      The charger link is above. I used vinyl as it matches the colors in front of the car. Even tho the cover is all rubber some alcohol and heat on the wrap worked pretty good and it sticks well. Time will tell how well
    16. #14
      Dec 2007
      I put my cable in the black flexible cable sheath when routing to the front grill. Protects against nicks.
    17. #15
      Moderator MvI_S60R's Avatar
      Nov 2013
      Stow, OH
      Theres a delaership in California which vinyl wraps the rear badges, wraps the wheels and front grille and also puts this little flag. Great idea on the part of management at that dealer to make them look more appealing to the market there, I called them and got all this info, its Volvo of Palm Springs. I plan on doin this to mine once I get it
      '06 S60R M66 | Blurple w/Sport Kit | 19" FC04A's | KW V2 | Hilton Stage 2.25 | DevilsOwn W/M | IPD:3" Oval Catless Exhaust | HD CA's | Adj. Toe Bars | 28mm Rear Sway | Snabb: Turbo Intake | Airbox | Big FMIC | Synapse DV | Colder Plugs | Strut Brace | Delrin S.B.'s | 20mm Spacers | 90mm Studs | My BUILD THREAD /// '20 V90 R-design on the way
    18. #16
      Feb 2019
      Long Island NY
      I started with photoshop and did 3 designs send it to my family members and winning one was used. The plastic from eBay seemed too thick for my liking.
    19. #17
      Dec 2019
      NY/NJ/MA
      I gonna quote James May here “I mean, really?”
      Not a fan of these thing on the bmws. Even less of a fan on the Volvos.
      https://youtu.be/Tuh2kBy897c
      09 BMW E92 335i: EFR 7670 Single Turbo / AP Racing / Wavetrac / TC Kline
      07 BMW R1200S: Akrapovic / Ohlins / Quickshifter
      19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization
    20. #18
      Oct 2019
      Cyprus
      can you share the plastic from ebay?
    21. #19
      Feb 2019
      Long Island NY
      This is what I was looking at but the colors are more for bmw.
    22. #20
      Oct 2019
      Cyprus
      That's not for R-Design grills.
    23. #21
      Feb 2019
      Long Island NY
      That is true modifications would be required.
    24. #22
      Feb 2019
      Long Island NY
      On another note the Ctek extension cable is now installed. So far happy with it. No need to open the hood anymore.
    25. #23
      May 2018
      Hawaii
      ha-ha, I see you also drive a BMW...M version perhaps?
    26. #24
      Feb 2019
      Long Island NY
      Well that was closest to the Swedish flag colors they had in Bavarian tint shop. And I think it works well with bursting blue. Can’t make this a race car.
    27. Remove Advertisements
    Similar Threads
    1. Had Vida 2012 running fine on W7 ultimate x64. But now, nothing.
      By RRRR in forum OBD, CANBUS & Engine Management
      Last Post: 08-20-2013, 02:11 AM
    2. today? nothing to do...
      By egovolvo in forum Photography
      Last Post: 04-08-2010, 02:23 PM
    3. Had some fun today... Nothing really car related.
      By vivek9856 in forum S80 (2007-2016)
      Last Post: 09-12-2008, 09:32 PM
    4. Replies: 53
      Last Post: 07-11-2008, 01:54 PM
    5. Replies: 4
      Last Post: 02-27-2006, 10:21 AM
