Crank specs for B18
    Results 1 to 9 of 9
      Jan 2019
      Crank specs for B18
      I was giving the machine shop the specs for the engine, that I have in a downloaded copy of the engine specs book, but what I couldn't find for him was the crank surface diameter for the connecting rods journals. The Main Bearing journals were there, but not the Rod Bearing Journals.
      Anyone have a spec or a source ?
      Oct 2009
      Is this what you need?
      Jan 2019
      Close. I think those would be the specs for the connecting rod end, but I was looking for the specs for where that clamps on the crank. The machinist is checking out the parts I gave him and needs to make sure the crank is still within spec for stock bearings.
      Where did you get that chart, by the way ? My manual has that listed as "Big End Bearings " and under that " Big end journals " .
      SwedeSpeed.com
      Oct 2009
      That's from an original Volvo service manual dated 4-63.
      I have specs from Glenn's, Chilton's and Haynes' manuals that may help. I'm running out the door now. I will post scans later today.
    7. #5
      Oct 2009
      Ok here are all the crankshaft specs I have:
      From a Glenn's Repair and Tune-up Guide 444-544-122-188 (Dec. 1967)
      From Chilton's Volvo 1956 to 1969 (1971)
      From Haynes 120 & 130 plus P1800 (1976)
    8. #6
      Jan 2019
      Perfect !
      Didn't know there WAS a B18A. I only knew about the B and D versions. Looks like even some of the Haynes books didn't list it.
      John
    9. #7
      Jan 2013
      Quote Originally Posted by JohnW63 View Post
      Perfect !
      John
      They’re all listed in the link I posted for you in your previous thread, “One Engine and so many cams”...
    10. #8
      Jan 2019
      I didn't read that chart clearly, as the web formatting was a bit of a mess. I cleaned it up and posted it in the other thread.
    11. #9
      Nov 2009
      Ypsilanti, MI
      All of the older Volvo green books refer to the rod bearing ends as "Big end bearings." The crank bearings are the "Mains."
      Lesky
      '73 164E
    12. Remove Advertisements
    Similar Threads
    1. Does anyone know whether a 123GT B18 is worth more than a 'standard' B18?
      By dcthompson in forum Pushrod Performance Forum
      Last Post: 12-04-2016, 01:45 AM
    2. Improved B18 Head on Rebuilt B18 bottom - Much performance improvement?
      By mdrains in forum Amazon P120, P130 & P220 (1956-1970)
      Last Post: 03-03-2015, 10:25 AM
    3. Volvo B18 and B20 Crankshaft Specs Needed
      By charlesme in forum P1800, 1800 & 1800ES (1959-1973)
      Last Post: 09-04-2014, 10:44 AM
    4. B18 or B20 crank pulley dubbel for AC wanted.
      By Bratsweden in forum Want Ads
      Last Post: 05-07-2014, 07:45 PM
    5. Replies: 2
      Last Post: 12-06-2011, 11:38 PM
