Wanted brake booster parts '99V70 N/A
    Results 1 to 3 of 3
      Apr 2014
      Looking for a brake booster check valve and possibly a whole booster. Most of the time the brakes work just fine, but a couple of times each trip when I apply the brakes the pedal is very high and very hard, with no apparent braking effect. I then must pump and/or press harder to get the brakes to resume normal operation. I'm guessing the problem must be one of 3 possible components - the check valve, the position sensor, or the booster itself. I don't want to replace all 3 and discover the problem is something else. I'd like to understand why it is happening before throwing time and parts at it. Car has ~100k miles on it and is all original. Suggestions please? I'd like to find a check valve in order to test whether that is the component I need.
      Senior Member ScottishBrick's Avatar
      Dec 2014
      Connecticut
      Check valve. Can remove and blow through it to test. Also check for proper vacuum line routing
      2003 V70 T5 - Mystic/Graphite - M56LK - 202k - K24/Greens/Do88 IC/SMF & P2R Clutch/DW300C/H&R/Bilstein TC/Delrin/316mm & 308mm Brakes - SteveO Tuned
      1999 V70 T5 - Pewter/R Graphite & Alcantara - AW42 - 295k - Daily/Work Wagon
      1999 V70 T5 - Nautic/R Graphite & Alcantara - M56H - 177k - Rescued
      1999 V70 T5 - Emerald/Graphite - M56H - 119k - Garage Queen
      2000 V70 T5 - Mystic/Graphite - AW42 - 240k - Moms Unicorn
      2000 S70 GLT SE- Mystic/Graphite - AW42 - 215k - Sisters
      Apr 2014
      Quote Originally Posted by ScottishBrick View Post
      I blew through the hose and no leaks apparent. Problem is intermittent so maybe still could be the check valve. Lowest price I've found so far is Volvo dealer. Surprising?
    Similar Threads
    1. Volvo Booster Seat? / Booster Seat Recommendations?
      By 12_Ice_white_S60 in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 08-17-2015, 02:56 AM
    2. Child seat, booster cushion/backrest for booster cushion
      By yellow95 in forum FWD & AWD Parts For Sale
      Last Post: 03-12-2014, 09:52 PM
    3. been to the gates of hell and back - cam seal job / VVT reset - 99v70 t5
      By domer94 in forum S70, V70 & V70XC (1998-2000)
      Last Post: 10-04-2010, 08:29 PM
    4. Parting 99V70 GLT Black with Charcoal
      By Chilled Man in forum FWD & AWD Parts For Sale
      Last Post: 04-23-2009, 11:24 PM
    5. rear cargo cover- 99v70
      By ZZZZZZZ in forum Want Ads
      Last Post: 08-26-2005, 06:19 AM
