2011 XC60 Timing Gear and Chain wearing out, fix or not?
    Results 1 to 5 of 5
      Mar 2020
      I was hearing a slight rattling kind of noise intermittently for a couple months, but now almost always when idling. No error messages, no performance issues.
      The mechanic said my timing gear and chain were wearing out, and that it would be a $5k job, which doesn't make sense for this car, even though it's in great shape otherwise. Mileage is 92k.
      How long can I drive it? My work commute is 4 miles.
      Thank you.
      Member
      Sep 2013
      New York
      It's probably the stupid torque rod engine mount that's bad and the engine mount underneath that. I highly doubt it's the chain... My IPD Poly torque mount radiates the chain noise when cold out because the polyurethane is hard when cold. I thought my chain was failing when the temps came down into the single digits. The mount was so cold and hard it created a lot of engine chain noise only in the cabin. I bet your oem mount and torque rod is toast and need to be replaced. Super easy and cheap fix.
      15 Volvo XC60 R-Design Platinum Pearl White Metallic, POLESTAR EXHAUST TDI Tuning Box, POLESTAR TUNED , IPD Rear Sway Bar and links, IPD POLY TORQUE ROD Koni FSD's, Eibach Loweing Springs, Powerflex Torque Bushing, Bloxsport wheel spacers
      Sold: 2008 Volvo C30 2.0 Java/Cosmic White, Manual, Elevate Tune, Weird OEM Mood Lighting Kit, EST Catback Exhaust, Koni STR.T, H&R Springs, Injen Intake, 19' BBS SR Wheels, Ion Yellow Fogs,
      SoldL 2006 Volvo V70R, Magic Blue, Stock
      Apr 2007
      Nashville
      Never seen or heard of a timing chain failing on the Si6 engine. Certainly not impossible, but I'd want a second opinion for sure.
      04 V70R Flash Green/Atacama6MT
      SwedeSpeed.com
      Member
      May 2012
      Ft Worth TX
      Get another opinion. The one way clutch on alternator, one way clutch on serpentine drive pulley, or one of the idlers are far more likely problems. The bearings in the gear drive unit (Rear engine auxiliary drive, READ) can fail but that noise tends to max out at 1700-2100 RPM and not be too loud at idle or at high engine speed.
      2004 V70R GT 255K miles purchased 9/15/12. Had several R company cars in the past and had to have one of my own.
      OBX DP but I've only just begun.............
      2010 XC60 T6 RD
      Several farm trucks, tractors, trailers, and a Suzuki Carry Kei truck.
    7. #5
      Jan 2011
      Arizona
      Could also be a worn water pump or serpentine belt tensioner or idler.
      All the suggestions already mentioned are more likely than the timing chain. Get a second opinion from a tech who specializes in Volvo (dealer or indy Volvo shop).
      2007 S40 T5
    8. Remove Advertisements
    Similar Threads
    1. 2010 XC60 T6 AWD - 105k mile service and timing chain
      By Squintz82 in forum XC60 (2010 - 2017)
      Last Post: 06-30-2019, 06:39 AM
    2. Why does Volvo using a Timing Belt Versus Timing Chain?
      By MyVolvoS60 in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 07-12-2017, 10:12 PM
    3. 3.2 in XC60---timing belt or chain?
      By mike11c30 in forum XC60 (2010 - 2017)
      Last Post: 02-27-2012, 11:42 AM
    4. Newer (2008 or 2009) 3.2L 6cyl. engin has timing belt or chain?
      By witchdoctorlee in forum Overseas Delivery Forum
      Last Post: 10-23-2008, 11:29 AM
