Exhaust mod options
    Page 1 of 2 1 2 LastLast
    Results 1 to 35 of 47
      Junior Member salv1983's Avatar
      Oct 2019
      Montreal
      Exhaust mod options
      Hey Guys,
      my S60 build is now at the performance stage in its transformation, I've gotten the car more or less visually the way i want it, interior and exterior give or take some questionable mods lol...
      but i wan to now focus on gaining some more performance and sound.
      I currently have the Vaitrix intake, polestar sway bar clone (in the making), the polestar tune, and Racechip is on the way. Whats missing is exhaust, power and sound.
      I know of 2 members here that have done some amazing exhaust work, one where the muffler was deleted and straight piped, an dthe other which had a full custom job done. I love both!
      Im curious does any one know if a resonator delete or muffler delete with shoot any error codes CEL?
      on my audi i was able to add a res-delete to give the car i nice throaty sound... not sure if the same will be for the volvo?
      i also know theres companies like HEICO that sell a premade kit, but WOW that price!!!!
      so what do you guys have, what do you suggest. my gaol is to get a nicer sound, but also having more HP wouldnt hurt, i just dont want to have any issues with warranty too..
      Junior Member visualv's Avatar
      Feb 2019
      California
      No error code with muffler delete.
      Sent from my ONEPLUS A6013 using Tapatalk
      2019 V60, T6 R-Design Polestar Engineered, Osmium Grey
      Ragnarok
      Oct 2019
      Montreal
      awesome, has any one done a res delete?
      SwedeSpeed.com
      Junior Member GonS60's Avatar
      May 2014
      Parrish, FL
      Personally I've been looking at that Heico Exhaust.. The price is high, but it's a quality product by a reputable brand; designed for the cars we drive. If that's out of your range and you know some folks that can do good muffler work to your liking, that's always a nice option.
      Sent from my SM-G975U using Tapatalk
      CURRENT: 2019 Crystal White Pearl S60 T5 R-DESIGN w/ P*
      PAST: 2012 Black S60 T5 w/Blonde Interior
    7. #5
      Sep 2019
      Bastuck makes a good quality system: https://shop.bastuck2.de/index.php?c...&hg2=500210040
      I think Bastuck makes the Heico exhaust systems (they're probably Heico's exhaust supplier).
      You can get a complete system with noticeably larger mid-pipes (70mm) that lack a resonator, or you can get just the muffler (along with an adapter to fit the stock mid-pipe).
      The full system should yield good power gains since the pipes are definitely larger than stock, and there's no resonator. The muffler only option would be good for someone who just wants a sportier (not too loud) sound. Even with just the muffler, performance should improve slightly since it's a turbo car. I'm trying to get one on order.
    8. #6
      May 2019
      Wayland, MA
      There is a valve in the exhaust, I think on the pass side if I remember seeing it when I was installing the mud guards. I wonder if you delete just the right side muffler...
    9. #7
      Feb 2019
      California
      There is one giant muffler with the single exhaust pipe from the resonator feeding into the middle and two pipes left and right to the exhaust tips
      Deleting the right side would not help with the airflow
      Ragnarok
    10. #8
      Junior Member Kamil's Avatar
      Nov 2019
      Quote Originally Posted by AJS1KR View Post
      How you can get this to USA? Do we have any dealership? Thanks
      2020 V60 CC
    11. #9
      May 2019
      Wayland, MA
      Ahhh right I forgot it is a single muffler. Must be a sort of dual path muffler. Guess that makes it complicated to Fab something up that uses the valve. I do wonder how it sounds if you override it to be open all the time.
      For the price of the heico they should make an integration with the stock switching system for that.
    12. #10
      Feb 2019
      California
      The valve is opened in Dynamic drive mode. It makes a little difference in sound but I suspect the extra opening is for the turbo exhaust to escape with less obstruction
      Ragnarok
    13. #11
      Oct 2019
      Montreal
      Quote Originally Posted by Power6 View Post
      I think if we do a res delete + a Y pipe deleting the muffler the car will sound amazing and must add more HP. Only issue would be possible drone...
      Sent from my SM-G973W using Tapatalk
    14. #12
      Oct 2019
      Montreal
      Does any one here k ow the thickness of the single pipe? And is it the same size as the pipes that exit the muffler??
    15. #13
      Feb 2019
      California
      The drone is real real bad. It is almost undrivable
      The stock pipe is 2.5"
      Ragnarok
    16. #14
      Oct 2019
      Montreal
      Quote Originally Posted by visualv View Post
      In your experience using the flowmaster do you think with the res delete and the muffler delete will still have a drone??
    17. #15
      Feb 2019
      California
      The custom shop did cut the res out for a test run. It is LOUD, but it sounds like a cheap car with a broken exhaust
      Ragnarok
    18. #16
      Oct 2019
      Montreal
      Even with the flowmaster??
    19. #17
      Feb 2019
      California
      We didn't do it with Flowmaster + res delete
      Ragnarok
    20. #18
      Oct 2019
      Montreal
      Ok I'll have to see. I definitely dont want it to sound cheap. But I'd still like to have more bass
    21. #19
      Feb 2019
      California
      The bass is pretty good with res+Flow. At a few Cars and Coffee, I get quite a few good comments about it
      Ragnarok
    22. #20
      Oct 2019
      Montreal
      I wish I had a spec of the exact size and bends... I could have it replicated in a 3" custom set up..
    23. #21
      May 2019
      Wayland, MA
      How did you figure that out? I know it's open on cold start. Just based on the sound change it seems to open up in other modes when you get on the throttle. But it's tough to be sure just by guessing. Did you probe it with a test light or something? Is it PWM variable or just switched on/off?
    24. #22
      Nov 2019
      What cars have the exhaust valve? Is this only on redesign trims ? I did not look under but by driving in different modes I did not hear exhaust difference.
      2020 V60 CC
    25. #23
      Sep 2019
      Quote Originally Posted by Kamil View Post
      Most likely with DHL, or FedEx. I wasn't able to find a dealer in the US, but I've contacted them directly. I'll post the prices if they get back to me.
    26. #24
      Dec 2019
      Appreciate that. I've also checked the bimmer forums, looks like the last U.S. shop stopped offering Bastuck sometime in 2016. Would like to know how their unit sounds. I remember their units do not sound obnoxious at all.
    27. #25
      Nov 2019
      Sounds good hit me with a pm if possible
      2020 V60 CC
    28. #26
      Dec 2019
      Below is a response from Bastuck:
      Subject: AW: Bastuck & Co GmbH - Ihre Konktaktanfrage
      Date: March 8, 2020 at 23:52:04 PDT
      Hi!
      Thank you for your email
      Naturally we still have a BASTUCK dealer in the USA :-)
      For getting a price for the required product please contact the following official BASTUCK dealer in the USA, which is:
      Republic SpeedShop
      Matt Cantos
      Shop Manager
      314 S 1st St
      US 07029 Harrison, New York
      Phone No. 0609 666 0188
      [email protected]
      https://republicspeedshop.com/.
      Or perhaps you are knowing yourself a company (Must be a garage, a car dealer, an automotive dealer or a tuning company),
      which could buy the BASTUCK product for you? In this case this company only have to contact me therewith I can give the company
      a customer number. After this I could send this company an offer for the enquired system by e-mail incl. shipping costs.
      Best regards
      Team Bastuck
    29. #27
      Sep 2019
      You bet, I'll pm you once I have costs.
    30. #28
      Sep 2019
      Quote Originally Posted by sclui56 View Post
      Hi!
      Republic SpeedShop
      Matt Cantos
      Shop Manager
      314 S 1st St
      [email protected]
      Best regards
      Team Bastuck
      Great info, thanks! I have a feeling their dealer in NJ isn't very active with their products, so i'm trying a different route. If their US dealer is active, they're not doing a very good job. I had never heard of Bastuck as a brand/company until I did some part number searches on Volvo mid-pipes (and I work in the automotive industry myself!).
    31. #29
      Oct 2019
      Montreal
      Saw this thought could be a cool option. Not sure of quality or sound...?
    32. #30
      Feb 2019
      California
      Why do you think this is a cool option?
      With our 2L 4 cylinder engine, the base sound is not very good, and IMHO, there is a danger of the exhaust sounding like a Honda with a cheap exhaust
      Ragnarok
    33. #31
      Oct 2019
      Montreal
      Initially it reminded me of the custom exhaust system another member here has... but personally I'm going to just delete the muffler
    34. #32
      We're going to be offering the Bastuck system on the Eurocompulsion site soon (they make systems we will be using for other vehicle platforms as well).
      Hopefully we can get some sound clips up and pricing available for NA buyers soon.
      VAITRIX USA | VOLVO SPA | Performance Parts & Tuning
      www.vaitrixusa.com| [email protected]
      Follow us:
      Facebook | Instagram | Youtube
    35. #33
      Feb 2019
      California
      Here is a shot of the Flowmaster FlowFx installed after the resonator
      Ragnarok
    36. #34
      Sep 2019
      My friends company received a quote on the exhaust. He's verifying shipping costs to California. Please PM me if you're interested.
      I'm debating between getting just the muffler (without flap), or the full system without flap. The only issue with a full system seems to be that it's designed for euro cars which have a petrol particulate filter. I wasn't sure if US S60's also have a petrol particulate filter. That would affect the length of the mid pipes, and would determine if the Euro spec full system is a bolt-on for US cars, or if the mid pipes would need modification to fit a US car. The muffler however is a bolt-on, and requires an adapter they sell to make the larger muffler bolt-on to the stock mid pipe.
      Installation for the flap system is overly complicated, and requires splicing into the vehicles rear electrical harness, which I'm not comfortable having done.
    37. #35
      Oct 2019
      Montreal
      Got some goodies in the mail from magnaflow!
      I originally wanted to go with flow master FX, but when checking out the price of the shipping to Montreal was almost double the cost of the muffler!! Hope this one does the trick...
    38. Remove Advertisements
    Similar Threads
    1. magnaflow exhaust mod part number? with JRL mod?
      By timwu12 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 08-19-2009, 11:38 PM
    2. Poll: To Mod or Not to Mod?
      By RearWheelPaul in forum General Volvo Discussions
      Last Post: 11-04-2007, 08:34 AM
    3. To mod or not to mod...
      By carsonlake in forum R Forum (2004-2007)
      Last Post: 05-02-2006, 04:15 PM
    4. Best mod under $500/Best single mod
      By shotdisc98 in forum S40 & V50 (2005-2012)
      Last Post: 08-15-2005, 08:11 PM
    5. Options, Options, Options... Send Help!
      By Ken in forum S60 (2001-2010)
      Last Post: 04-01-2001, 03:29 AM
