Correct oil for 2010 T6
    Results 1 to 5 of 5
      Feb 2009
      South Africa
      I switched to a new dealer for servicing and they used Castrol Magnatec 5W-40 full synthetic, whereas the previous dealer used Castrol Edge Professional 5W-40 which is also a full synthetic oil.
      I like to keep a litre or two (OK, quart) of oil available and wanted to buy same - only to find that there are two different specification Castrol Magnetec 5W40 oils available - one with a A3/B4 specification and the other with a C3 specification. The dealer is not very helpful as they buy bulk in 44 gallon quantities and does not seem to know which specification it is, hence my cry for help. The Castrol web site also does not help as it indicates a "special formulation" for this model.
      Which one is the correct one for my car? For clarification it is the 210kW / 265 hp engine and not the more powerful one fitted from late 2011 onward.
      Regards
      Pierre
      Current: 2016 V40 D4; 2010 XC60 T6
      Previous: 2015 V40 D3; 2007 S60 2.5T; 2004 S60 2.0T; 2002 V70XC 2.4T Autotech Tune; 1996 850 GLT
      Member mgm7890's Avatar
      Nov 2013
      USA
      2005 S40 2.4i
      Member Ocean Racer's Avatar
      Oct 2009
      Melbourne / Australia
      You need 5w30 with A5/B5 specification.
      02 XC70 R PROJECT TERRÄNGKÖRNING LANDVAGN
      04 V70R PROJECT LANDBARGE
      11 XC60 R-DESIGN PROJECT HEICO
      Nov 2002
      Russell Twp, OH
      Quote Originally Posted by Ocean Racer View Post
      That's what I use in my three SI T6 cars. The only oil where I live that's readily available and meets that spec is Mobil 1.
      May 2014
      My dealerships takes my pennzoil platinum 5w30 for oil changes. It's up their with the best "boutique" and more expensive oils like fuchs and amsoil.
    8. Remove Advertisements
    1. the correct Trans oil?
      By zn14 in forum S60, S60CC & V60, V60CC (2011-2018)
      Last Post: 02-21-2019, 09:09 PM
    2. Correct timing belt interval for 2010 S40? 100K or 120K?
      By h_curtis in forum S40 & V50 (2005-2012)
      Last Post: 01-15-2018, 04:38 PM
    3. Correct oil pickup tube for the R?
      By 1nstyR in forum R Forum (2004-2007)
      Last Post: 08-28-2014, 09:39 PM
    4. 2010 XC60 T6 vs 2010 XC90 3.2
      By earthling in forum XC60 (2010 - 2017)
      Last Post: 05-14-2014, 04:20 PM
    5. 2009 S80 T6 vs 2010 S80 T6
      By hokieone in forum S80 (2007-2016)
      Last Post: 12-12-2012, 09:19 PM
