What transmission is in these?
    Results 1 to 6 of 6
      Awaiting Approval
      Mar 2020
      Hello group. Ok, from what I have read, the 2002 S80 T6 has the GM transmission, I hear only the 5 cylinders have the Aisin transmission. However, I did a decode here https://www.vindecoderz.com/ on a car I am considering buying and it says it has the AW55-50SN Transmission. Is that decoder site just full of it or did a few of these cars come out with an AIsin transmission?
      And BTW the car is being sold fairly cheap. Reverse gear is gone on it.
      Yeah, there's 5 cyl model with that tranny.
      S80 T6 2001 IPD Tune w/torque delete, Ferrita Dual 2.5" DP/CB 3" exhaust, Volvo Tranny cooler, Bilstein HD's, H&R Springs, IPD Anti-swaybars, IPD End-links, IPD Skid Plate, AEM Water/Methanol kit, IPD Lower Tranny Mount, Ultra Racing Front & Rear Strut Tower Braces, and Front and Rear undercarriage braces, Heico Front Spoilers, 17x8 R Pegs, R Calipers and Rotors, Front Girodisc, 5 & 10 mm H&R spacers, etc...
      Feb 2015
      Deep River, CT
      The 6 cylinder comes with the GM, the 5 cyl with the Aisin. The Aisin wouldn't fit with the 6, the block was too long, so they went with the GM which could not handle the torque - especially from the Twin Charge.
      2004 late and 05/06 were 5 cylinder cars.
      2010 S80 V8/AWD Executive Electric Silver / Anthracite Black 66K miles
      2002 V70 AWD
      Others in my garage: 2000 Ford Explorer V8, 1968 Chris Craft Apache 37
      Previous: 2006 S80, 2000 V70XC AWD/SE, 2002 Porsche 986S, 2000 V70SE (put to sleep);1973 164E w/4 Speed & Electronic Overdrive (oh, I should have kept it);1968 142S Dual-Carburetted (should have kept this one too!)
      SwedeSpeed.com
      Thb, I replaced my failed tranny around 115K. I bought it at 95K. So I killed it in 20K miles. When I put the new one in, I installed a tranny cooler. I've put 100K on the replacement with hard shifting and only a small shudder in the 1-2 gear so far. It might not be a great tranny, but you can improve it's longevity under stress. Sample of one - YMMV.
    7. #5
      Apr 2020
      Quote Originally Posted by SkyWriter View Post
      I bypassed the radiator and put a transmission cooler in our 235K 03 Odyssey and flushed with Havoline Synthetic Multi Vehicle.
      Installed a Transgo Shift Kit, Filter and flushed with the Havoline Synthetic Multi Vehicle on the 03 S80 T6 with 135K miles. Shifts are quick and instantaneous during WOT. Almost a little snappy off the line but not jolting like the BM Shift Kits of old in my previously owned 78 Cougar XR7 with a 351W. Both vehicles have benefited from the Havoline. The Odyssey has not seen temp over 170 at the cooler even in the summer. Odyssey going on 1.5 years and S80 1 year. The small shudder could be fluid level related. Took a couple tries to finally see where exactly the level was on the stick. Was not to capacity after the Transgo Kit and flush and it shuddered from 1-2.
      Cooler - Cheapest and purchased here
      https://www.ebay.com/itm/HAYDEN-TRAN....c100667.m2042
      Transgo - Cheapest and purchased here. FITS: 4T65E "Including Volvo 4T65E"
      https://www.ebay.com/itm/Transgo-Shi...cAAOSwwo1XfsC2
      Used Chevron gas over for 35 years while in CA
      https://www.amazon.com/HAVOLINE-2265...s%2C159&sr=8-1
      Flush - Most people attach a tube so you don't have to be under the car
      https://www.youtube.com/watch?v=0bnjbmUXFVQ
      Shift Kit Install Same GM Trans - Replaced the rubber hose with a transmission or fuel line rubber hose. GM no longer stocks that part and the local Transmission Shop won't tell me what they used.
      https://www.youtube.com/watch?v=TIB4qx0Gkj8
      Shift Kit Install Same GM Trans - Do not use Vavoline especially Maxlife - Have personally experience bad shift in other older cars as others
      https://www.youtube.com/watch?v=62VyLDbBSIM
    8. #6
      Good to know! I was going to do a tranny kit years ago. Never got around to it. Still I've put 15 years of tranny beating and it's still going strong after 100k. I'm always auto-shifting that thing.
    9. Remove Advertisements
    Similar Threads
    1. Transmission leak. Any transmission rebuilders/specialist?
      By JWATT357 in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 12-23-2011, 04:35 PM
    2. Replies: 14
      Last Post: 06-22-2011, 09:05 AM
    3. switching an automatic transmission to a manual transmission.
      By Need More Speed in forum S60 (2001-2010)
      Last Post: 10-04-2009, 02:51 PM
    4. Auto Transmission to Manual Transmission
      By iwklee in forum S60 (2001-2010)
      Last Post: 09-29-2008, 08:42 PM
    5. "Transmission Fluid Temp High" or "Transmission Temp Overheat" message
      By 024tnfi in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 08-13-2005, 06:26 PM
