Code 400c
    Results 1 to 2 of 2
    Thread: Code 400c
      Mar 2019
      cape town
      Code 400c
      Volvo DTC ECM-400C
      The diagnostic trouble*code*(DTC) is stored if the efficiency of the three-way catalytic converter (TWC) deviates too much. The diagnostic trouble*code*(DTC) is diagnosed when driving under specific driving conditions. ... Damaged catalytic converter.
      Anyone experience this and what wss done to remedy this problem of engine light staying on as a result of this problem on S40 T5 2006?
      Sent from my SM-G960F using Tapatalk
      Global Moderator tmtalpey's Avatar
      Jun 2004
      Eastern MA
      Um, maybe it's the catalytic converter?
      Seriously, if you're looking to avoid replacing that, you might try replacing the rear O2 sensor, which will have to be replaced anyway since it's 99.9% likely to be destroyed when removing it from the 15yo cat. After that doesn't fix it, you'll be able to swap it over.
      2005 V50 T5 AWD 6MT w/Heico tune, Heico exhaust, Bell intercooler, IPD TCV, Viva Forge CBV, Elevate rear swaybar and torque mount, Snabb shift kit, etc.
      2016 XC60 T6 AWD
      1956 PV444 complete, running
      1956 PV444 very original, very rough
    4. Remove Advertisements
    1. 2007 SR, CEL, P0420 - ECM-400C - Catalytic converter efficiency
      By volvolars84 in forum R Forum (2004-2007)
      Last Post: 01-05-2016, 10:28 AM
    2. Trouble shooting ECM-400C CEL -- possible gas cap gasket failure? (w/Pic)
      By Young Satchel in forum V70 & V70XC & XC70 (2001-2007)
      Last Post: 09-11-2015, 11:07 AM
    3. Replies: 3
      Last Post: 03-18-2014, 01:12 PM
    4. ugh ecm-400c Fuel system leakage
      By Body Massage in forum R Forum (2004-2007)
      Last Post: 07-20-2011, 11:58 AM
