S60 Wireless Charging Behind Waterfall - Attempted?
    Results 1 to 4 of 4
      Aug 2019
      Mesa, AZ
      Lightbulb S60 Wireless Charging Behind Waterfall - Attempted?
      Just sending this out to see if anyone has attempted installing Qi charging behind the waterfall.
      That section where you can put your wallet or stuff you want stored out of sight?
      My iphone X lays flat on the existing rubber pad.
      If no one has, I may be interested in mocking something up with a spare waterfall dash part.
      Granted the phone would be out of sight... but that's probably a GOOD thing for most drivers I see, on their phones, while driving.
      Dec 2019
      See if you can mock one up, I thought I read somewhere about one in the cupholder, but behind the waterfall on that flat piece would be ideal. I'd certainly be interested in one for my Note 10+ if I could get it to fit, currently I just put the phone in the armrest but it would make nice use of that space to put the phone back there and have it charging.
      May 2019
      Chicagoland
      I was recently thinking about that or maybe just a 12V port or USB plugs back there so I could cap the 12V outlet by the cupholders and keep that area cord free.
      EDIT:
      On further thought, I would be fine with just tapping the existing wiring to a second 12V outlet behind the waterfall and use that as the primary power source. This would be nice because
      1) Keeps the cupholders cord free, as mentioned
      2) significantly reduced risk of spilling into the outlet if it's capped
      3) I can just tuck the cords behind the waterfall - which I never really use - when not in use.
      That would still leave the cupholder one available, if necessary, as well as the backseat outlet.
      2018 V60 T5 Dynamic AWD, Osmium Grey Metallic
      Previous cars: 2003 Infiniti I35, 2003 VW Passat GLX Variant, 1993 Toyota MR2 Turbo, 1991 Honda Accord LX
    5. #4
      May 2020
      consideration
      Before you install anything back there, remember that the manual override for the transmission selector is underneath that pad. As long as it can be removed with the pad, it should be fine to work with. Having a dead battery/electrical system and no way to pull it out of park is a real nightmare.
    6. Remove Advertisements
    Similar Threads
    1. Replies: 7
      Last Post: 02-24-2020, 07:02 AM
    2. Tapping in to more power behind the waterfall dash.
      By grt2106 in forum C70 (2006-2013)
      Last Post: 01-04-2017, 09:50 AM
    3. Solution for storage area behind waterfall?
      By bhom920 in forum XC60 (2010 - 2017)
      Last Post: 02-10-2015, 12:38 PM
    4. Coin Tray/Tray behind the console waterfall
      By Trex1200r in forum XC60 (2010 - 2017)
      Last Post: 09-27-2013, 10:50 AM
    5. Original Xbox MINT, 2 wireless controllers, 1 wireless HS! Warranty!!
      By slowrey in forum Miscellaneous Classifieds
      Last Post: 01-11-2006, 06:03 PM
